Author Topic: G5 Part Number Request and Another Question - Photos Included  (Read 6051 times)
Online Groover
    • Scooteropolis
I can't seem to find this part number. Maybe someone can help. It's the rubber dust cover that is used on the emergency flasher switch. You can see that in the first photo:
The other question is... What goes here - Should I just add washers (the Allen bolt at the top of the fork tube)? Or do I just have too long of a screw? I removed the windshield brackets so that was filling that gap, and now that's where the screw stops. I also noticed some oil under where the screw goes.. is that normal and is that where you put oil in the forks? Please advise.
Thanks for the assistance!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: G5 Part Number Request and Another Question - Photos Included
« Reply #1 on: March 09, 2015, 09:09:06 AM »
You can get various types of boots for the switch from McMaster-Carr: http://www.mcmaster.com/#toggle-switch-boots/=w8fz9z . I sometimes find them at Lowe's as well.
For the damper fixing bolt, you just need a shorter bolt. The oil could be that someone has already drilled the top of dampers to drain and refill them or it could just be some spilled from when the fork oil (atf) was last changed. I'd put some sealer on the shorter bolt and call it good.
« Last Edit: March 09, 2015, 09:11:14 AM by Antietam Classic Cycle »
Online Groover
    • Scooteropolis
« Reply #2 on: March 09, 2015, 09:50:35 AM »
Perfect, thanks for the reply and links!
1980 Vespa SI Moped
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #3 on: March 09, 2015, 09:55:30 AM »
Cover is here.
http://www.harpermoto.com/toggle-switch-cover.html
And we can do the bolts as well.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Online Groover
    • Scooteropolis
« Reply #4 on: March 09, 2015, 10:21:25 AM »
Good deal, I'll get that on my next order then. Thanks for the link too!
1980 Vespa SI Moped
