Author Topic: Leaking Rubber Hose  (Read 7823 times)
MotoGoosy
Leaking Rubber Hose
« on: March 13, 2015, 04:05:59 PM »
About 3/4 inch hose on top of engine has a crack in it and leaks a little oil.  My manuals don't show it so I don't know what to order.  Anybody got a pic or diagram?
dilligaf
Re: Leaking Rubber Hose
« Reply #2 on: March 13, 2015, 04:47:28 PM »
It's the black hose-right?  ~; :BEER:
Matt
« Reply #3 on: March 13, 2015, 04:59:49 PM »
Yea, the one that's leaking
Online fotoguzzi
« Reply #4 on: March 13, 2015, 05:35:06 PM »
probably vibrated the hose clamp loose.
MotoGoosy
« Reply #5 on: March 13, 2015, 05:40:48 PM »
The crack is clearly visible.  Looks like it's part of the evap. system.  Goes up under the tank.
Online fotoguzzi
« Reply #6 on: March 13, 2015, 05:43:42 PM »
3/4" would be the oil breather hose going to frame. best to get the stock part because of the tight bends.. make sure the check valve on the motor end isn't all rusty or anything.
MotoGoosy
« Reply #7 on: March 13, 2015, 05:44:28 PM »
Hmm, don't see it in either one of those diags.  Goes straight down into the engine box behind the cylinders.
MotoGoosy
« Reply #8 on: March 13, 2015, 05:45:27 PM »
Yes.  I'll have to take the tank off to get to it though.
« Reply #9 on: March 13, 2015, 06:19:08 PM »
You still haven't told us which model. There are quite a few breather/condensate return systems that vary between models.
Online fotoguzzi
« Reply #10 on: March 13, 2015, 10:21:37 PM »
Pete this is the special EV Paint shaker that has more vibration than a Harley, the owner wishes for an aftermarket rubber mounting kit so he can safely cruise below 2300 rpm around town.. If I remember right he's never seen over 4,000 rpm because it vibrates so violently..
http://wildguzzi.com/forum/index.php?topic=74758.0
« Reply #11 on: March 13, 2015, 10:52:29 PM »
He better not ride a 1400.
MotoGoosy
« Reply #12 on: March 13, 2015, 10:58:55 PM »
'02 EV1100.
« Reply #13 on: March 14, 2015, 12:10:56 AM »
So is it the main breather hose that fits on the pipe that comes out of the top of the bell housing and goes up to a spigot just behind the steering head? These are crack prone with age and heat.
