Author Topic: OHC Guzzi  (Read 10776 times)
Offline Seagondollar
  • Wake Forest, NC
OHC Guzzi
« on: March 16, 2015, 09:54:35 AM »
Ennio Carraro of the Guzzi club posted these photos on Facebook about the last open house at Mandello.  Of interest to me where these photos of a true OHC big block twin Guzzi.
2002 BMW 330i
1988 Toyota MR2
1974 V7 Sport
Re: OHC Guzzi
« Reply #1 on: March 16, 2015, 09:57:11 AM »
It's a small block..  ;D Very kool, though.
  • Wake Forest, NC
Re: OHC Guzzi
« Reply #2 on: March 16, 2015, 10:02:11 AM »
Just heard that on FB.  Maybe there is hope for the small block V7 Sport in terms of HP!
2002 BMW 330i
1988 Toyota MR2
1974 V7 Sport
Re: OHC Guzzi
« Reply #3 on: March 16, 2015, 10:05:40 AM »
Love the belt routing.  Sure to keep the rubber properly warm.    :o
Re: OHC Guzzi
« Reply #4 on: March 16, 2015, 10:20:47 AM »
Re: OHC Guzzi
« Reply #5 on: March 16, 2015, 10:35:31 AM »
I was thinking they same thing.
Push rods work fine on (relatively) slow-revving V-twins (vs. high RPM inline fours), why add the additional maintenance items of cam belts if you don't have to?
Re: OHC Guzzi
« Reply #6 on: March 16, 2015, 10:50:19 AM »
The cam belt routing is really close to the exhaust header, which would surely shorten the belt's usable life.
Re: OHC Guzzi
« Reply #7 on: March 16, 2015, 12:00:21 PM »
IIRC, that bike revs to ~ 10k rpm, doubt it could do that with pushrods.
Re: OHC Guzzi
« Reply #8 on: March 16, 2015, 02:20:27 PM »
If it could, it wouldn't for very long.. ;D
Offline Bob Wegman
Re: OHC Guzzi
« Reply #9 on: March 16, 2015, 05:22:59 PM »
Harley 250 short stroke Sprints revved to 10,500 rpm.  Pushrod engine.
MGNOC # 20848
AMA# 548668
Online Tom
Re: OHC Guzzi
« Reply #10 on: March 16, 2015, 05:58:26 PM »
So all the work that's done to it.  What are the benefits?  Top end?  Reliability?  More Torque?  'cuz I have something that's different?  I think the latter.  :-*
Re: OHC Guzzi
« Reply #11 on: March 16, 2015, 06:24:44 PM »
It's been posted here before and IIRC, the horsepower was around 100 and the whole bike was very light. I'd count those as a "benefits".  ;)
Offline Guido Valvole
Re: OHC Guzzi
« Reply #12 on: March 16, 2015, 07:16:29 PM »
100 hp from a smallblock engine?!? Must be small horses… I *would* like to see the combustion chamber design as it looks to be SOHC with inline valves. Perhaps an improvement over Heron heads but not likely to produce 150-200 bhp/liter. Hey, even 50 or 60hp at the rear wheel and curb weight under 400 pounds could be major fun!
cr
V50 II
V50 Monza
Le Mans 1000 (IV)
Martinez, CA
Online Tom
Re: OHC Guzzi
« Reply #13 on: March 16, 2015, 09:23:32 PM »
I'd count those as benefits too until the next repair is needed.  ;D
Re: OHC Guzzi
« Reply #14 on: March 17, 2015, 05:47:05 AM »
I'd imagine that the guy that is capable of building it isn't too concerned about that.. ;D :BEER:
Offline rbond
Re: OHC Guzzi
« Reply #15 on: March 17, 2015, 01:42:37 PM »
The only way that configuration would work, is to have the cams push directly down on the valves. There is no room for rockers, the ports would be 90 degrees to normal; exhaust coming out the side of the cylinder instead of the front, intakes going straight under the tank too. Still seems to be a Heron head, OHC setup does not improve anything to me. Just a new way to change belts more often.....
2012 MG V7C
1976 Suzuki GT500A
1978 Suzuki GS400C (long gone)
1973 Suzuki TS 100K (first new bike)
1969 Honda S90 (very first bike)
Re: OHC Guzzi
« Reply #16 on: March 17, 2015, 02:06:49 PM »
If the cam lobes were ground conical (not as outlandish as it sounds, the Aprilia Pegaso Cube had cams with conical lobes), then there could be a narrow valve angle.
In any case, I'm only relaying information I remember reading about it here on Wildguzzi in the past. Maybe someone has more information about it. I searched the web and came up empty.
