Author Topic: Ever wondered what the tool looked like that crimps on bezels?  (Read 13924 times)
I sure have. Found this photo over on the Morini Rider's Club forum.
Offline normzone
Re: Ever wondered what the tool looked like that crimps on bezels?
« Reply #1 on: March 16, 2015, 12:13:42 PM »
I wonder when that image was made - imagine...it was somebody's job to operate that.
Being in QA, I always wonder what the failure rate / mode of a process is. That one looks pretty reliable, but there's usually a way to screw something up if you try hard enough.
« Reply #2 on: March 16, 2015, 12:17:43 PM »
 Then there is the older technique.
Offline mtiberio
    • TiberioRacing
« Reply #3 on: March 16, 2015, 12:46:55 PM »
the key is the shape of the "die" that sits below the bezel in the picture. It rolls the edges around and under as the instrument is pressed down.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
dilligaf
« Reply #4 on: March 16, 2015, 01:27:44 PM »
Until today, Not really.  Thanks for the picture.  :BEER:
Matt
« Reply #5 on: March 16, 2015, 01:38:33 PM »
I've designed and built automated tools using a similar process back in the day. For the two bezels on the Commie Thumper, I just machined a cavity that was a light press fit to stick the instruments in to keep the bezels from deforming. Made it deep enough the tack puller I used wouldn't over bend them on removal, then machined off the top at the break line and used a hardened flat punch with a polished radius on it to roll it back over on reassembly. Took about 10 minutes all in all to remove and re-install the bezels. Putting the guts from a Yamaha in the MZ tach, however...  ;D
Offline Tobit
« Reply #6 on: March 16, 2015, 02:02:25 PM »
Yes I had wondered about that.  I knew it had to be some sort of press and die when I tried crimping one back on after a needle came loose.  Doing it with pliers ain't pretty.  Thank goodness for the rubber fascia.
Tobit
Roman, '86 LM IV
« Reply #7 on: March 16, 2015, 02:06:24 PM »
That's good.
Now the one we REALLY want to see is the one that UNcrimps the bezels .... !
« Reply #8 on: March 16, 2015, 02:16:27 PM »
That's good.
It'll be similar. Just the working tool will be different.
« Reply #9 on: March 16, 2015, 02:17:09 PM »
One of these might work.
Offline normzone
« Reply #10 on: March 16, 2015, 02:18:01 PM »
A Tineye search found the first illustration on the Velobanjogent blogspot post - a few images down shows the tool used to reinstall. The nail polish color is nice.
« Last Edit: March 16, 2015, 02:18:43 PM by normzone »
Offline mtiberio
    • TiberioRacing
« Reply #11 on: March 16, 2015, 02:37:49 PM »
That's good.
easy if you do not want to save it...
« Reply #12 on: March 16, 2015, 02:44:01 PM »
Yes I have, thanks for posting!
« Reply #13 on: March 16, 2015, 04:05:44 PM »
Emailed Greg Bender with that photo and he sent me one back that he found. Same idea, just with a lathe.
Offline Groover
    • Scooteropolis
« Reply #14 on: March 16, 2015, 04:23:30 PM »
That's good.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline huub
« Reply #15 on: March 16, 2015, 05:27:48 PM »
i used the trick with the lathe a couple of times,
makes fitting the bezels a 5 minutes job
« Reply #16 on: March 16, 2015, 05:43:10 PM »
I think the whole idea is to R & R the piece and not repair it.  Drives there Parts Department.  :-*
« Reply #17 on: March 16, 2015, 05:55:17 PM »
Yamaha has that figured out.  ;D All the king's horses and all the king's men wouldn't have gotten that bezel off without damage. That said, it was *really* well done and sealed. It's no wonder they last forever.
« Reply #18 on: March 16, 2015, 09:19:56 PM »
or until the needle falls off. ;D
Offline jetmechmarty
« Reply #19 on: March 16, 2015, 09:44:03 PM »
The needles don't fall off.  The two little screws that hold the faceplate on back out and roll around at the bottom of the glass.
Marty (in Mississippi)
No Guzzi right now
« Reply #20 on: March 17, 2015, 06:42:58 PM »
I guess you missed the part of my reply with emoticon.   :-*  I was being sarcastic.  ;D
Offline cwiseman
    • C&D Motorsports
« Reply #21 on: March 17, 2015, 06:51:54 PM »
When I needed to repair my RD350 speedo I used a dremel cut off wheel and opened the bezel. When finished with repairs JB Weld to the rescue. Popped the rubber trim piece back on and you never see the repair.
618-544-RIDE
Offline JoeW
    • The Guzzi Doctor
« Reply #22 on: March 17, 2015, 08:55:11 PM »
Thanks for the picture Charlie but, where do you get one? I'm using a Canuck750 special, I may try to modify it.
Joe Walano
« Reply #23 on: March 18, 2015, 07:48:37 AM »
Oh no.  I was just playing along.   ;)
No Guzzi right now
« Reply #24 on: March 18, 2015, 07:53:42 AM »
Have any of y'all investigated or had experience with this place?    http://www.joellevinecompany.com/
No Guzzi right now
« Reply #25 on: March 18, 2015, 09:40:46 AM »
Since North Hollywood stopped doing motorcycle instruments, I recently sent "Arveno's" Ambassador speedometer to Joel Levine. North Hollywood used to charge $325 for a complete rebuild, Joel Levine was $385 with a one year warranty. Two week turnaround. Looked beautiful when he was done, Marco will have to fill us in on how well it works.
Offline Goosecoop
« Reply #26 on: March 18, 2015, 12:02:01 PM »
He did a beautiful job on my speedometer. Too bad he doesn't do electronic tachs.
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
