I know there are probably many firms out there that will check the accuracy of a torque wrench;Give us a few cheap and dirty ways to check them at home,The obvious way is against a known weight on a lever but if you don't have that, then what.I ask because I have 2 reading quite a bit different, like 30%
I have a square hole socket that allows me to mate up my pointer indicater wrench with my click type wrench. Grab the handles firmly and torque ad read the needle when the other clicks. BTW, with click types you should return the vernier to zero after use.
Glad I use bending beam torque wrenches. If it is zeroed, it is calibrated. :BEER:
I manage a collection of tools that my employer gets calibrated once a year for ISO 9001 purposes. The calibration house charges $30 to do a torque wrench.My veteran mechanic buddy says the difference in readings between a pricey torque wrench and a Harbor Freight special can run 10%.
Shirley I'm not the only one who finds torque figures stated in Foot Pounds instead of Pounds Feet annoying, even the torque wrench has it backwards
https://youtu.be/jdVR6T0cxXg
Now that's the way to do it.
Wayne, I assume you have a beam scale with the little pop out pin, my simple pointer one is next to useless.
OK, I'll bite. Why do you prefer pound feet as opposed to foot pounds. Wrong word plural?
In the old Allison engine fuel control manuals it specifies inch/ounces for things, I don't know if Rolls Royce rewrote those or not. Thirty five years ago I heard that NASA did a study and found that the most consistently accurate torque of fasteners was achieved by an experienced mechanic doing it by feel. I have tried to find that document but haven't been able to so I wonder if that is an urban legend . I like to use my torque wrenches but would hesitate to use one on a drain plug, for that I use the ever popular "feel"
