Author Topic: will VDST Centurion-m work for California 1400  (Read 6680 times)
Offline Gootsz
« on: March 19, 2015, 10:10:29 AM »
I have the Techno research Centurion-m digagnostic set. Will this work for a new California 1400. If not what do i need to do home stuff like TPS,etc.
Micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
Re: will VDST Centurion-m work for California 1400
« Reply #1 on: March 19, 2015, 10:22:52 AM »
Doesn't the free Guzzidiag software work on the Cali 1400 now?
That said, I BET you never reset the TPS unless it's been remapped or the throttle body has been replaced (like the 1TB V7).
I mean, there's only a single throttle body, nothing to adjust or synchronize there...
Offline ibis1
« Reply #2 on: March 19, 2015, 10:24:49 AM »
I too would like to know what options are available for the 1400, including diagnostic abilities. I tried hooking her up to our Range Rover interface and for some strange reason she did not want to communicate! Is the Guzzi factory tool available? Thanks for any and all advice. :BEER:
2010 California Vintage (Gone)
1971 750 Ambassador (Gone)
2014 California Touring
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #3 on: March 19, 2015, 05:31:19 PM »
Guzzidiag does read a lot of parameters. and can even do some throttle reset and learning. And is free, only 20$ cables.
Paul
Daytona 1225, Stelvio 1151
Offline lucian
« Reply #4 on: March 19, 2015, 05:45:07 PM »
I noticed that both of my first and second services have specified reset tps on the invoices. I don't know why other than maybe it is routine after valve lash adjustment.
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #5 on: March 19, 2015, 06:08:43 PM »
It's a bit difficult to reset the TPS on a California 1400 when it doesn't have one!  I'd be asking for a refund on work not done.
Offline lucian
« Reply #6 on: March 19, 2015, 06:17:24 PM »
Oh my!
« Reply #7 on: March 19, 2015, 08:43:47 PM »
That's not entirely accurate.
It's still got a Throttle Potentiometer and it DOES need to relearn throttle position (though NOT after a valve adjustment):
A couple of relevant excerpts from the service manual.
It's not the same as what we've come to think of a TPS on say a CARC bike, but there are some throttle position circuits that to be considered.
NEW CONTROL UNIT ACTIVATION PROCEDURE and REPROGRAMMING
After installing the control unit for the first time, or after REPROGRAMMING the control unit with a
different or more updated mapping, turn the key to ON and wait 3 seconds; during this time the control
unit carries out throttle position acquisition. Connect to diagnosis instrument and check that the statuses
"Front throttle automatic self-learning" and "Rear throttle automatic self-learning" are "Carried out" and
"Handle self-learning" is "Not carried out" (this last status entails Urgent service being displayed on the
instrument panel). If front and rear throttle automatic self-acquisition indicate "Not carried out" go to
phase 1, if indicate "Carried out" go to phase 2. Phase 1: current errors have probably been detected
by the control unit: solve these malfunctions and check the two statuses. Throttle Self-learning can also
be checked from the Parameter adjustment (screwdriver and hammer) screen page. Stage 2: Carry out
the Handle Self-learning from the Parameter adjustment (screwdriver and hammer) screen page and
check that Handle Self-learning status is Carried out. If not OK the voltage detected on the throttle is
out of scale (check with diagnosis instrument) or current errors have been probably detected by the
control unit: solve these malfunctions and repeat the procedure
California 1400 Electrical system ELE
DIAGNOSTICS INSTRUMENT: PARAMETERS
Throttle correction
· Example value with key ON: 0.0°
· Example value with hot engine at idle: -0.5°
An acceptable value is between -1.5° and + 1.5°
Throttle Potentiometer 1 (degrees)
· Example value with key ON: 6°7°
· Example value with engine at idle: engine hot 5.5°, engine cold 6,5°
Throttle Potentiometer 1 (voltage)
· Example value with key ON: 800 mV
· Example value with engine on: engine hot 760 mV, engine cold 800 mV
Throttle Potentiometer 2 (degrees)
ELE SYS - 121
· Example value with key ON: 5.5°
· Example value with engine on: engine hot 5.5°, engine cold 6.5°
Throttle Potentiometer 2 (voltage)
· Example value with key ON: 4200 mV
· Example value with engine on: engine hot 4240 mV, engine cold 4200 mV
Throttle Limp Home position
· Example value with key ON: 824 mV at 6.7°
Voltage stored in the control unit corresponding to the Limp home position
Throttle lower position
· Example value with key ON: 480-510 mV
CAUTION
BEFORE CARRYING OUT ANY TROUBLESHOOTING, CAREFULLY READ THE GENERAL TROUBLESHOOTING
CONCEPTS FOR ELECTRICAL DEVICES AT THE BEGINNING OF THE CHECK
AND CONTROL SECTION IN THE ELECTRICAL SYSTEM CHAPTER.
Offline pauldaytona
« Reply #8 on: March 20, 2015, 07:01:16 AM »
I suppose connecting the bike to PADS, checking if there are errors, if it needs map update and so on are standard procedures with service. Are those all seperate specified on the bill?
Reset TPS costs one second when bike is connected.
Paul
father guzzi obrian
« Reply #9 on: March 20, 2015, 08:44:48 AM »
Ask for your TPS unit back from the dealer, the must have removed it ~;
Hi Kiwi Dave, you coming back anytime soon?
Cheers,
Jon
