DB Killer
Topic: DB Killer (Read 5612 times)
scra99tch
DB Killer
March 22, 2015, 06:48:20 PM »
How do I get that thing out?
Last Edit: March 22, 2015, 06:48:59 PM by scra99tch
2007 California Vintage
guzzisteve
"Just Ride It"
Re: DB Killer
Reply #1 on:
March 22, 2015, 06:59:33 PM »
Sawzall, not kidding.
leafman60
Re: DB Killer
Reply #2 on:
March 22, 2015, 08:49:25 PM »
Why not start by holding the bolt head and screwing the nut off? The baffle should slip out after removing the retaining bolt.
scra99tch
Re: DB Killer
Reply #3 on:
March 22, 2015, 09:33:01 PM »
Tried, bolt is pinched in there, the nut seems to hold onto nut-thing. I thought there might be a trick.
guzzisteve
"Just Ride It"
Re: DB Killer
Reply #4 on:
March 23, 2015, 04:03:44 AM »
You can try to bend DB in to get a wrench on the outside nut. I didn't have much luck doing that. Used a sawzall & cut it off.
PeteS
Re: DB Killer
Reply #5 on:
March 23, 2015, 06:01:45 AM »
Sawing the bolt out is the easy part. The tube is likely rusted in place by now and it doesn't look like there is much to grab to pull it out. Might try putting the end in a can of kerosene or similar for a few days.
DB Killer
