Author Topic: shocks spring compressor tool  (Read 5354 times)
Offline arveno
    • ddleathers.com
« on: March 22, 2015, 07:58:42 PM »
Hi All
I just got a set of heavy duty springs for my ambo ikon shocks, and i was wonder if is there any cheap way to compress the springs to replace them ?
Thanks a lot
Marco
Offline Matteo
Re: shocks spring compressor tool
« Reply #1 on: March 22, 2015, 08:51:50 PM »
Tie a rope top to bottom of spring and twist with a pipe. As cheap as it gets.
Did this once and bought a spring compressor.
« Last Edit: March 22, 2015, 08:54:38 PM by MMNorth »
Online rodekyll
« Reply #2 on: March 22, 2015, 09:30:01 PM »
Hose clamps are as good as anything if you don't want to spend money.
dilligaf
« Reply #3 on: March 22, 2015, 09:39:59 PM »
« Reply #4 on: March 22, 2015, 10:25:03 PM »
This
Found it on ebay years ago,
Real simple and safe too
Orange Guzzi
« Reply #5 on: March 22, 2015, 11:06:46 PM »
This
I build a tool like this.  I used a 2 x 4, 6 feet long, with a hinge on one end and a bracket about 2 feet from the end.  I attached one side of the hinge to the end of the board and the other end to a leg of my work bench.  The bracket was like the one on this tool and was attached to the board.  Had plenty  of leverage and it worked.  Hard to describe, but it worked great.
dilligaf
« Reply #6 on: March 23, 2015, 07:23:28 AM »
Looks simple enough but, without a vice, how do you secure the shock so it won't move?  :BEER:
Matt
biking sailor
« Reply #7 on: March 23, 2015, 07:45:08 AM »
I've made spring compressors with chain links cut into "J"s, welded to short pieces of pipe and clamped together with all-thread and hex nuts.
Basically made from leftovers in the workshop.
