Author Topic: Glue Recommendations  (Read 9245 times)
Offline Groover
    • Scooteropolis
« on: March 24, 2015, 07:56:34 AM »
I have two projects that require some good glue and looking for some recommendations.
1) The first type is to glue the rubber floorboard mats to the metal floorboards.
2) The other glue type I need is to glue the seat cover to the seat pan. This is the original seat cover and original metal pan but some of the factory glued areas at the edges under the seat are coming apart. There have been gluing-attempts by the previous owner, but they weren't successful.
These are for my G5.
I'm thinking something industrial of some sort, but all I've got at home is flavored Elmer's glue .... (just kidding  ~;)
Thanks for the assistance.
« Last Edit: March 24, 2015, 07:57:22 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: Glue Recommendations
« Reply #2 on: March 24, 2015, 08:31:49 AM »
Shoe Goo
Offline Rich A
« Reply #3 on: March 24, 2015, 08:53:39 AM »
For (1), weatherstrip glue (I got some from NAPA) works well, may work for (2) also.
Rich A
Online acogoff
« Reply #4 on: March 24, 2015, 08:58:33 AM »
     3M weather strip adhesive.
Marshall County Minnesota USA
Offline Groover
    • Scooteropolis
« Reply #5 on: March 24, 2015, 09:50:24 AM »
Thanks for the replies. I think I'm going to try the Pliobend Charlie is suggesting. Seems to have great reviews, and they have it at the local ACE hardware.
Is this the same? Says LV...
http://www.acehardware.com/product/index.jsp?productId=19708286
Thanks again for the help.
1980 Vespa SI Moped
Offline Perazzimx14
« Reply #6 on: March 24, 2015, 09:54:57 AM »
3M Super77 spray adheasive. I works to keep the fiber lid gasket on my Big Green Egg. It has seen several hundred  heat/cool cycles and keeps on sticking.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline Rich A
« Reply #7 on: March 24, 2015, 10:00:09 AM »
This is what I was recommending. One minor advantage of this over Pliobond (at least for floorboards) is that the weather strip stuff is black.
Rich A
Offline Groover
    • Scooteropolis
« Reply #8 on: March 24, 2015, 10:14:53 AM »
Rich A
Good point. I think I'll use that for the floorboards then and the Pliobond for the seat. Can never have enough glue around the house, especially when it's also used recreationally.. (just kidding again  ~;)
Thanks again!
1980 Vespa SI Moped
Offline drlapo
« Reply #9 on: March 24, 2015, 10:29:32 AM »
Gorrilla Snot
« Reply #10 on: March 24, 2015, 11:55:16 AM »
  This is a really sticky thread.
Offline krglorioso
« Reply #11 on: March 24, 2015, 11:11:22 PM »
I like "Fantastic Goop", or "Shoe Goo" which I've used to bond rubber soles to leather soled riding boots for better purchase on the tarmac, and to seal around the Stones' spoke nipples when doing tubeless conversions.  This is the toughest adhesive I've ever tried and I've tried lots of them.
Ralph
Ralph
2004 Moto Guzzi Breva 750
2017 Honda CB-500F
Offline Waterbottle
« Reply #12 on: March 25, 2015, 02:33:38 AM »
I have tried a lot of different ones, but the one that sticks in my mind (  :D ) is Laminex 440T contact adhesive. Good enough to have a hot saucepan placed on the kitchen bench without lifting.
 It is a horrid yellow colour ( color ), but it will bond Poo to a blanket  ;-T
Try local kitchen cabinet workshops ?
2015 Griso SE Rosso
2012 Stelvio 8V
2009 Griso R  Track only
76 GT 750 Suzuki
« Reply #13 on: March 25, 2015, 08:03:32 AM »
And I have used E6000 adhesive for my seat cover.  They mostly are just variations on a contact adhesive.
Offline kevdog3019
« Reply #14 on: March 25, 2015, 08:18:37 AM »
This for the floorboard.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline boatdetective
« Reply #15 on: March 25, 2015, 11:16:34 AM »
It's all the same stuff- contact cement.   All the suggestions would work fine.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
« Reply #16 on: March 25, 2015, 12:22:59 PM »
That does bring up another point.  Some of them do not label the correct way to apply a contact adhesive.
apply...wait 2 to 10 min....clamp pieces together...I like to use a hard roller along the surfaces to make sure they are 'seated' properly
make sure you have them where you want them cause they will stick where they touch!  :)
Offline Groover
    • Scooteropolis
« Reply #17 on: March 25, 2015, 12:35:57 PM »
Thanks again, plenty of suggestions and much appreciated. I'll follow-up once I get these done and report back on how went (goes?).
« Last Edit: March 25, 2015, 12:36:15 PM by Groover »
1980 Vespa SI Moped
« Reply #18 on: March 25, 2015, 02:53:04 PM »
The 3m  77comes in a tube and a spray.  I like the spray for big surfaces.  I use if to stick the foam layers of a seat together and to stick the foam to the seat pan.  I tack the seat cover onto the foam with it too, but sparingly in case I need to repair it.
I put a closed foam insulation on the inside of my boat hull with the 77 spray.  It has stood up to temp cycles, moisture and freezing, day-to-day abuse and vibration just fine.  I'll be using it to carpet the inside of my storage compartments on the trike, too.
E6000 is more of a sealer (calk) than an adhesive.  We use it to join bulkheads and make weathertight joints -- not so much for a glue.
A very good SEALER adhesive is 5200.  I seal my boat's top house-to-hull joint (about running 35') with it and reseal ~7 years.  You can cut out a bad foot of the stuff and repair the bead with a good bond between the new and old stuff.
