Clutch Disc, Clutch Gear Versions, LM2
Topic: Clutch Disc, Clutch Gear Versions, LM2 (Read 4941 times)
Dobermann
March 25, 2015, 03:40:57 AM »
I have to order new clutch discs for my LM2. Is there a way to distinguish what type clutch gear I have - fine splined or older version?
guzzisteve
"Just Ride It"
Re: Clutch Disc, Clutch Gear Versions, LM2
Reply #1 on:
March 25, 2015, 04:11:21 AM »
Not till you pull off trans.
Dick
Reply #2 on:
March 25, 2015, 04:28:31 AM »
When you get there; shallow spline clutch hub teeth are 2mm deep. Deep spline hub teeth are 4mm deep. Shallow hub teeth are truncated at the crest and root. Obvious difference. Good luck.
