Author Topic: need to replace '09 Norge headlamp bulb; any hints?  (Read 4512 times)
Offline blackbuell
« on: March 27, 2015, 09:54:09 AM »
The left low beam has expired on my '09 Norge; will try to replace it this weekend. Can I do this without removing any bodywork? Does the black plastic dash panel have to come off?
Any hints would be appreciated.
Thanks,
Jon
Offline samfrank
Re: need to replace '09 Norge headlamp bulb; any hints?
« Reply #1 on: March 27, 2015, 10:11:44 AM »
I had to replace (I thought) the right side bulb on my '13 Norge. You have to remove the black plastic panel just in side the faring on which ever side needs replacing. Once I got into it I discovered a loose connection and once reestablished all was good. When your in there you have to remove the black rubber cover to gain access to the bulb housing. It wasn't hard but took a bit of time. To remove the black plastic part you have to pry out the coupler piece. I think there are two, one fore and one aft. You'll need them to replace the black plastic part. If I can do this anyone can!
Sam
1973 Eldorado
2013 Norge - moving to Arizona to live with John.
2015 Yamaha FJR1300
Offline blackbuell
« Reply #2 on: March 27, 2015, 10:24:02 AM »
Thanks for the feedback Sam. I guess the first gen and second gen Norges have different dash panels: mine only has one large black plastic panel around the instruments; not one on each side. I guess I need to remove that fragile-looking sucker.
Will I be able to use an inexpensive bulb that I can buy at an auto parts store? Or, does it require some exotic, expensive part?
Jon
« Reply #3 on: March 27, 2015, 10:30:54 AM »
Jon
I shouldn't say since mine was an 07. It wasn't particularly fun, and doesn't look like anything I've seen at an auto parts store.
Offline Waltr
    • Europa Macchina
« Reply #4 on: March 27, 2015, 10:55:11 AM »
Nothing that rare or obsolite.  H3-55watt bulbs for the low beams and H1-55watt for the high beams.  If one side is gone I would get two because the other is probably right behind.
www.motoguzzipa.com
2012 Norge
Offline blackbuell
« Reply #5 on: May 04, 2015, 08:34:50 PM »
Waltr,
Thanks for the information; I bought two Sylvania H3 bulbs at the local auto parts store; seem to work fine (I did replace both sides). But man, what a pain-in-the-ass! Had to remove (well, not really completely) the dash panel, the windscreen, and the cover for that bizarre corkscrew device that must have been designed by Leonardo da Vinci. Had to work in some tight quarters. Is there an easier way?
Jon
« Reply #6 on: May 04, 2015, 08:44:36 PM »
Now do it in 5min !! Welcome to my world Jon.  Getting the dash around the bars w/o scratching anything is a chore.
Offline blackbuell
« Reply #7 on: May 05, 2015, 06:49:33 AM »
Steve,
Now that I've been through it, I could probably do it again in about 1/2 hour (no way could I get close to doing it in 5 minutes); if the bulbs only need replacement every 50 K miles, I might not get the opportunity to try it again. But who knows, maybe I'll keep riding the Norge past 100 K; the bike really has grown on me; has now become my all-time favorite bike.
Jon
