Author Topic: Stelvio CARC failure in Oz AND South Africa  (Read 133335 times)
Offline bcls482
  • 2021 V85TT Centenario, 2012 Stelvio NTX, KLX250-S
Re: Stelvio CARC swingarm failure in South Africa
« Reply #210 on: October 21, 2015, 05:02:39 PM »
Could you post the year and serial number of your bike.  I have a 2012 and I am wondering if Guzzi had a bad batch of swingarms because this problem seems very rare, but very worrying at the same time.
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #211 on: October 21, 2015, 06:02:24 PM »
 I'm trying to collect numbers, and have now 1.5 If someone knows how to contact the Australian owner to get me the VIN. I can lookup production date with that. Three bikes out of a few thousand is very litte to draw conclusions. Who has seen the production process in  the factory, knows that not all part come and get mounted in a first in first ouit way, it's in batches. If you have a VIn or enginenumber and another that is 10 higher, that doesn't tell you the low number is made earlier. If they are mode then 100 apart, then chances are good that the lower number is made earlier.
 Engines waiting to be tested in the blue test cabines.
Paul
Daytona 1225, Stelvio 1151
« Reply #212 on: October 21, 2015, 06:50:56 PM »
Well I can confirm they the holes are threaded, M8. Not sure of the clips are press in or themselves threaded, I pried one out. If I can I'll post a couple of pics later.
« Last Edit: October 21, 2015, 08:17:11 PM by Vasco DG »
Offline jacksonracingcomau
Re: Stelvio CARC failure in Oz
« Reply #213 on: October 21, 2015, 10:01:59 PM »
If the swing arm supports the wheel from one side, and it broke under the rider's and its own weight,  why is the tire tipped and turned the way it is?   Shouldn't  the gearbox side be down?  Wouldn't such an accident try to pull the unit apart?  The unit looks compressed. It sort of looks more like impact damage to me.  YMMV
You could represent the manufacturer in court, they need expert witnesses like you, in fact they're are a few on here who seem to have this expert opinion, hope none of you have it happen yourselves, be a horrible epitaph.
« Reply #214 on: October 21, 2015, 10:05:18 PM »
There was link to auction site in other thread would've had VIN but no longer available
Doubt owner kept record of VIN but importer would certainly know, probably Pickles (auction house) too
I'm still puzzled why importer didn't test broken arm and / or shock etc, I would've for sure, selling as is let a whole lot more people know, not wise IMHO
Guess they're treating it like cam problem, case by case appraisal, if in warranty they'll pay
If out you need FSH, guess they'll actually pay in both cases but only if you push. If people pay for cams they're happier, why not swinging arms ?
Doubt they'd fight a claim in court, just down to whether anybody needs to do it, I'd expect dealers to deal with this, if factory don't pay they're next in line for a writ.
« Reply #215 on: October 21, 2015, 10:54:54 PM »
Got the Vin# of the Oz bike, PM'd it to Paul to see if its close to the other known failures.
MotoZA
« Reply #216 on: October 22, 2015, 03:34:04 AM »
Or preload adjustment. If the preload is not set properly, and the shock is being bottomed out, that might add a lot of impact type stress. I found the spring on the stock 2009 pretty weak when loaded.
Rebound, as one of the forum members PM'd me, can also cause problems. If riding along on a bumpy road with corrugations and rebound damping is set too high compared to compression damping, the spring will pack (basically it doesn't get enough time to expand between loads from the corrugation). The the shock can then easily "bottom out" since the coils will be touching one another at that point, or they might be very close to one another so that effectively you have no more travel on the spring. All the load then goes through the wheel and swing-arm into the frame. Still, one would hope that the swing arm is stronger than the wheel, which clearly was not the case in my failure since the wheel and tyre is still in perfect condition.
I've been on rides where guys hit a washout in a gravel road and they bend rims, if that happens you should definitively inspect the suspension and ancillary parts.
« Last Edit: October 22, 2015, 03:42:33 AM by MotoZA »
« Reply #217 on: October 22, 2015, 05:08:26 AM »
Nearly right, sorry, have to say it now
Shock will bottom out long before spring coil binds on anything halfway well designed
First you hit the rubbery bump stop, then that compresses till it can't (very high speed comp damping)
Then the load goes somewhere else
Might be problem, might not.
MotoZA
« Reply #218 on: October 22, 2015, 05:59:55 AM »
Just closing the loop...
Here's another, almost identical failure: http://wildguzzi.com/forum/index.php?topic=79597.0
« Reply #219 on: October 22, 2015, 06:17:49 AM »
Yes, perhaps this thread should be merged. That way the poorly analysed target will be even easier for haters to aim at.
Alternatively, we can try and get some USEFUL data and evidence to make informed decisions and choices. Here? Fat chance I fear......
Offline brlawson
« Reply #220 on: October 22, 2015, 06:58:41 AM »
With all this negative discussion around the Stelvio it might be good to inject some positive vibe.
50 plus paying homage to the creator.
https://www.youtube.com/watch?v=84taL6pT4og
B. Lawson
Madison, AL
'72 Suzuki Titan 500
'77 Yamaha RD400
'79 BMW R/65
'03 California Titanium
'10 Stelvio ABS
2000 v11 Sport
MotoZA
« Reply #221 on: October 22, 2015, 07:05:36 AM »
My goal is not trying to make it easier for haters.
I accept that it may be bad luck on my part, but I'm not the only person in the world who can strike it bad, so I think it's fair that other riders of Stelvios should know about this.
If we had useful data, we wouldn't be having this conversation. Perhaps try to see this as an attempt to get some useful data, unfortunately I can't add anything more than what I wrote in my original post.
« Reply #222 on: October 22, 2015, 09:27:34 AM »
Yes, the bump stop was destroyed on my original shock. Not saying anything about the overloaded rear seat. :thewife:
I had the shock resprung and revalved. Now it never bottom out, and seldom reaches fully extended.
« Reply #223 on: October 22, 2015, 09:37:15 AM »
Again, parts like this need to be designed for worst case loads times a safety factor like three.  Worst case could be a bottoming shock with a 250 lb driver and 300 lb passenger.  If it is, design for three times that load.
Offline WitchCityGuzzi
« Reply #224 on: October 22, 2015, 09:48:31 AM »
2016 V7II Stornello
2011 Griso SE
2009 Stelvio
2004 Ballabio
1979 V1000 Cafe
1970 Ambassador
1966 Stornello Sport
1967 Aermacchi 250SS Sprint
« Reply #225 on: October 22, 2015, 10:10:47 AM »
When you load 500 pounds on a 600 pound motorcycle, your problems started some time before that. Time to rethink what you're doing.
Offline sib
« Reply #226 on: October 22, 2015, 10:23:09 AM »
From my observations, that's more the norm than the exception, at least among the patrons of the motorcycle bars in my area.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #227 on: October 22, 2015, 10:36:00 AM »
Yes, you design not for sensible customers, but for worst case customers.  Back in the '80s I was given the task of designing some quick-erect military vehicle decoys.  The design had been narrowed down to use standard frames that were available like the ones you see at trade shows that start out as a bundle of aluminum sticks, and when you give a pull, they quickly make a wall suitable for hanging display posters and things like that.  My question was then whether or not they'd hold up to life in the military.
I recruited a coworker, and we took two of these frames, one from each of two manufacturers, to a park and dragged them around in the dirt, pulling on single aluminum tubes, dropping large rocks on them, and doing anything we could think of to damage them.  We learned that one was less susceptible to damage than the other, but the damage it did sustain was not field repairable.  The other one suffered more damage, but the aluminum tubes mainly popped out of their end fittings and could be replaced by hand.  The test taught us a lot.
The point is that the design was based on what could happen from abuse, not what happened when treated with respect by nice, careful people.
Offline rss29
« Reply #228 on: October 22, 2015, 10:48:34 AM »
I agree, but I'll bet that's still well within the bike's GVWR. I regularly load 300+ pounds of rider and passenger on my 400 pound bike and it handles it with ease. The Stelvio is marketed as an adventure bike, ready to take you and all your gear to the far corners of the globe. All components on the bike should be up to the task. This certainly isn't cause for panic, but the failures we've seen are pretty dramatic. If I had a Stelvio I'd definitely be out in the garage right now with a flashlight inspecting the swingarm for cracks, assuming there even is a crack that shows up before failure.
Offline tazio
« Reply #229 on: October 22, 2015, 10:50:44 AM »
Ratio seems reasonable to me.
Might be because I ride a mountain bike..
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
« Reply #230 on: October 22, 2015, 11:25:09 AM »
Uh oh.. :thewife: She's a redhead, too..
« Reply #231 on: October 22, 2015, 04:09:24 PM »
I understand that. My feeling is that since all three failures we know about have been on machines from what seems to be a very small window of manufacture there was probably a bad batch of castings. This is particularly worrying because nobody knows how many might be flawed.
I'll be writing to our tech and warranty wallahs later today and trying to see if we can shake some action. If we can get some input from the factory on what Vin's might be affected they can be summoned in for, at the very least, an inspection. The last thing I want is people, particularly my customers, being injured or killed.
Offline lucky phil
« Reply #232 on: October 22, 2015, 07:42:43 PM »
Well after reading the details of both arm failures and seeing the pictures I would be drilling out the cable mount hole to the thread root depth and would then do a dye pen check (kit price around $30au) All being well I would then cold work the hole and use a rubber well nut to hold the cable clip.
Looks fairly clear to me the cable clip hole is most likely source of the crack propogation but even if its not the above wouldnt hurt.
Ciao
« Last Edit: October 22, 2015, 07:46:25 PM by lucky phil »
« Reply #233 on: October 22, 2015, 07:48:24 PM »
That is a very considerate and noble thing to do.
« Reply #234 on: October 22, 2015, 08:57:07 PM »
No, it's the right thing to do and it's also arse-covering. If I think there might be a problem and I've alerted the 'Powers That Be' nobody can complain I didn't pass on information. Arse Covered! An email trail is a useful thing.
« Reply #235 on: October 22, 2015, 10:11:13 PM »
And this is exactly what I'd be looking at if I was inspecting the bikes
Symptom & cause
Repeated bottoming hard could be taking swingingarm where it was never meant to go, finally to heaven, repeat, could be
OP (Bill?)
Is your bump stop intact ?
Do you know where the Pickles bike went ?
Wayne
 why your shock doesn't fully extend leaving bumps is another issue,  , go pro film of shock working hard would tell you.
If your back wheel leaves the ground without shock extending, next hit will be big & probably harsh, hitting sleeping policeman fast good test.
Hope that translates into Merkan, is colloquial for "speed bump"
Offline JeffOlson
« Reply #236 on: October 22, 2015, 10:28:01 PM »
I wonder if Ewen McGregor is taking an extra swing arm with him on his next adventure...
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #237 on: October 22, 2015, 11:00:11 PM »
No idea where it went. I called pickles and they were less than helpful. I was going to bid on it but it went stupid.
Re: Stelvio CARC swingarm failure in South Africa and OZ
« Reply #238 on: October 22, 2015, 11:24:36 PM »
Can anyone with a Stelvio post the allowable gross weight of the bike? Should be on a sticker somewhere.
« Last Edit: October 23, 2015, 11:10:17 AM by oldbike54 »
MotoZA
« Reply #239 on: October 22, 2015, 11:32:36 PM »
OP (Bill?)
Yes, as far as I could see. Would even slight damage be visible?
