Just to update this in case people thought it was bullshit. Swingarm and torque rod got on the 'Big White Bird' this AM, Should be in the steaming fleshpots of Kyalami in seven to ten days.
Hi people, I'm new around here - trying to learn before joining the Family so to speak.Forgive me if this suggestion is dumb but why not be proactive and just Tig the threaded hole if that's the weak spot and Araldite a clip into place to hold the Brake Line? Cheers Maurie.
Well you could, but getting a competent welder that knows what material to use and is ok to weld cast might be the issue. Just adding another variable.I'd still go with the open the hole to the thread root dia, dye pen test, cold work and use a rubber well nut.Ciao
Point ��� what about filling with quick metal and reinforcing in and out with carbon fibre?Maurie.
it seems a lot of these bikes leave the factory with minimal grease in the bearings.
My theory is that some bonehead at a bearing manufacturer specs a very tiny layer of grease for bearings, assuming they are well sealed, and assuming they are used at higher speeds. Any more grease would just get hot and leak out. But they don't realize that in this application, the swingarm pivot bearings only have a slight amount of motion, and the seals are lacking. So they really need a heavy dose of grease to protect them from rust. But that connection is never made, and the bearing manufacturer doesn't even see the issue. Well, he does see additional bearings sold to repair the rusted out, under greased, bearings.
Kinda glad I got a Norge.
I bet the steering head bearings need more grease too. Bob
The Headstock Bearings are better protected from the Elements (at least they are on the Stelvio), and they don't do quite so much 'work' either, rotation-wise, so the Grease issue isn't so critical.Always best to check/clean/re-lube as required though.
In my current career as a millwright, I have found that bearings that don't spin (in other words bearings that operate through less than 360 degree rotation) fail early. I have my own theories as to why this is, but I see it often.
I found that with my R1150R Paralever Bearings, replaced the $60ea. OEM's with Nylatron Bushings care of an ADV. inmate - I'm one of the riders testing them. The TRB's were badly Brinelled, they have little movement and end up wearing grooves across the race that the rollers just sit in. Cheers Maurie.
F*ck this shit! Has the new swingarm arrived yet?Should be there before Christmas!Pete
I was going to ask, would not synthetic plain bearing types work better for those applications?Seems someone thinks so, test results will be interesting. The nylatron is in the class is self lubing plastics yes? Self cleaning too if I remember correctly and this is the same material I was thinking if. Even when gritty they continue to function well.
