Wheel bearing size small block
Topic: Wheel bearing size small block (Read 3675 times)
magrahamkp08
Hatchling
March 30, 2015, 04:13:47 PM »
I have a 1984 v65c. I plan on swapping out the forks with something better. But to fully plan the swap I need to know the front wheel bearing size. If somebody knows the size please pass along.
Antietam Classic Cycle
Happily stuck in the past.
Re: Wheel bearing size small block
Reply #1 on:
March 30, 2015, 04:36:16 PM »
6203 2RS1 bearing = 17 mm i.d. x 40 mm o.d. x 12 mm wide
magrahamkp08
Hatchling
Reply #2 on:
March 30, 2015, 04:37:31 PM »
Roger that. Thanks for the quick reply
Mayor_of_BBQ
Instagram: @Mayor_of_BBQ
'Ever thus to deadbeats, Lebowski'
Reply #3 on:
March 30, 2015, 05:28:24 PM »
Please post about your progress and what you come up with for the swap! Don't forget the :pic
magrahamkp08
Hatchling
Reply #4 on:
March 30, 2015, 06:13:05 PM »
This is the current progress. Which might as well be no progress.
I need to source a new piston and ring kit. Then I'll bead blast the engine and put it all back together.
