Author Topic: Fork seal tool  (Read 7339 times)
Offline Perazzimx14
Re: Fork seal tool
« Reply #1 on: March 31, 2015, 01:37:36 PM »
I do not but I can tell you a piece of 1-1/2" PVC schedule 40 pipe will do the same thing for about $52 less.
« Last Edit: March 31, 2015, 01:39:29 PM by Perazzimx14 »
Re: Fork seal tool
« Reply #2 on: March 31, 2015, 03:24:27 PM »
  Cut the pvc tubing lengthwise and it becomes adjustable for fork diameter.
Offline radguzzi
Re: Fork seal tool
« Reply #3 on: March 31, 2015, 04:36:35 PM »
vf,
I just bought that very tool while out here on the West Coast and away from my tools, I needed to do the fork seals on the recently acquired V11 Jackal.
What are your concerns, it is just another fork seal driver that I will add to the set when I get home... a good tool.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Re: Fork seal tool
« Reply #4 on: March 31, 2015, 04:47:54 PM »
My question is how one driver can install seals from 32 mm to 47 mm? How does that work? Something like this one made by "Stockton".
http://www.amazon.com/gp/product/B0089GM3ZW/ref=pd_luc_rh_sbs_01_03_t_img_lh?ie=UTF8&psc=1
« Last Edit: March 31, 2015, 04:53:41 PM by Antietam Classic Cycle »
Offline youcanrunnaked
Re: Fork seal tool
« Reply #5 on: March 31, 2015, 04:54:59 PM »
 :+1
see the tube at the top of the below image:
Plenty of descriptions on the internet as to how to make and use this, if it's not already self-explanatory from the picture.
Offline radguzzi
Re: Fork seal tool
« Reply #6 on: March 31, 2015, 06:55:15 PM »
Oooops...
Charlie,
That is the one that I bought...I have only used it the one time so far and completely forgot about the "one size fits many" plastic driver thingy.   ::)
Tough to get old I have heard...  ;D
I have offered to do Normzone's fork seals on the white Bassa but he needs to hurry.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline redrider90
Re: Fork seal tool
« Reply #7 on: March 31, 2015, 07:31:24 PM »
I use A rubber mallet and or wood interface until I get even with the fork slider. I then take a socket invert it so the solid end faces the seal and genteelly tap it into place.
Never ruined a seal yet. But I've only done it 3 or 4 times.  ;D
Red 90 Mille GT
redrider
Re: Fork seal tool
« Reply #8 on: April 01, 2015, 06:22:24 AM »
Lube first. A paint stick and gentle taps working around the seal. No damage for 40 years.
Re: Fork seal tool
« Reply #9 on: April 01, 2015, 08:43:19 AM »
:+1
For WP, Ohlins and other forks of the male slider sort, PVC pipe will not work. If all you ever work on are "right side up" forks, then a section of PVC would be fine.
Re: Fork seal tool
« Reply #10 on: April 01, 2015, 04:39:19 PM »
I was not aware of this.  Please elaborate.  Isn't a USD fork the same as an RSU fork, only, inverted?
« Last Edit: April 01, 2015, 04:40:10 PM by youcanrunnaked »
Re: Fork seal tool
« Reply #11 on: April 01, 2015, 04:49:53 PM »
RSU forks don't normally have anything at the top to "trap" a PVC driver. USD on the other hand have axle and caliper mounts at the bottom, so a solid tube driver (vs. split) would be trapped.
« Last Edit: April 01, 2015, 04:50:25 PM by Antietam Classic Cycle »
