Charging Indicator Light
Topic: Charging Indicator Light (Read 4242 times)
NMPete
New Egg
April 08, 2015, 11:09:36 AM »
Hi - I am upgrading a Bosch 240W alternator system from the diode board and mechanical regulator to an electronic one from Euro MotoElectrics.
It has wires for everything except the wire to the dash charging indicator light ("idiot light").
Does anyone know how to install a diode or something to make the "idiot light" work?
Kiwi_Roy
Re: Charging Indicator Light
Reply #1 on:
April 08, 2015, 12:43:15 PM »
Did you buy an Endurolast EDL?
Which bike?
You could try wiring the light to the alternator DF that way it would indicate the difference between battery + and field. It would sort of work backwards becoming brighter as the battery charged up and less field is applied.
You could also remove the +12 from the lamp and run it to ground, it would work the other way, I suggest you just try it with a spare lamp first.
rbm
Gaggle Mentor
Reply #2 on:
April 10, 2015, 08:09:53 PM »
Bosch charging systems on BMW motorcycles have the charge indicator wired between switched +12V and D+ on the alternator. This provides power to excite the field windings and create the initial conditions for the alternator to work. Check out these two works:
http://www.buchanan1.net/charge.html
http://www.thisoldtractor.com/guzzitech.dk/pdf/charging-around-the-circuit-john-noble.pdf
There should be a connection labelled D+ to which you can connect the light. As for the "light", BMWs have successfully been modified to use:
- incandescent bulb of about 3-6W
- 12V LED
- two series connected 56 Ohm 2Watt resistors
Last Edit: April 10, 2015, 08:11:58 PM by rbm
- Robert
2011 Moto Guzzi V7 Racer
Moto Fugazzi
Waiting on a sign from God, or a nod from hell.
Reply #3 on:
April 10, 2015, 11:17:52 PM »
I would just add a volt meter and be done with it.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
NMPete
New Egg
Reply #4 on:
April 11, 2015, 09:22:26 AM »
Hi - Thanks for the comments.
Yes, I have an Endurolast rectifier/regulator - they recommend just adding a voltage monitor as Ken said. This system uses both the DF and the D- terminals for regulation, so not sure if adding the light circuit will change anything.
Moto Fugazzi
Reply #5 on:
April 11, 2015, 07:46:35 PM »
I have the Electrosport 510 on my 2001 V11S, and when the fuse melted, the charge light went on. That left me stranded for a bit. I have since added a volt meter in a very conspicuous place.
If the endurolast has a cheap looking fuse holder, you should think about replacing it.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
