Author Topic: Greasing replacement disks before installation?  (Read 5057 times)
Offline Tony/CT
« on: April 08, 2015, 02:37:56 PM »
I watched a video of a guy replacing disk brakes and he greased the back of the pads before putting them into the caliper. I've never seen this before. Should this be done before installation?
Re: Greasing replacement disks before installation?
« Reply #1 on: April 08, 2015, 02:43:10 PM »
 Probably just a bit of anti squeal lube . Be careful with it .
Offline ccoli
  • What? Me Worry?
« Reply #2 on: April 08, 2015, 02:48:33 PM »
I've seen a small amount of Anti seize used but one must be very careful not to grease the disks as your subject line states. Think it helps control rust and squealing.
Wisconsin MGNOC Rep
03 EVT/EML hack, 99 Bassa, 2-78 Robins, 32 Sport15, Ambo/EV custom.
« Reply #3 on: April 08, 2015, 03:13:14 PM »
I normally give mine a quick shot of anti-squeal from a spray can on the back side. Not sure it helps. It doesn't appear to hurt.
« Reply #4 on: April 08, 2015, 03:19:37 PM »
Last time I tried a special name brand anti-squeal spray adhesive, I was at a motorcycle meet for a week.  The guy with the spray can and I both followed the directions carefully to apply it, and put things back together.  Sure enough, the squeak was gone...    ...for darned near the rest of the day!  I don't bother any more, and don't have more than an occasional mild squeal at push-around-the-garage speeds.
Offline lucian
« Reply #5 on: April 08, 2015, 04:53:46 PM »
Sounds like grease or anti seize would just invite dirt and crap  along for the ride. Maybe graphite would be better?
Offline Mike Tashjian
« Reply #6 on: April 08, 2015, 06:07:57 PM »
There is a product used for disc brakes to stop squealing.  It is used on the back of the pad and kind of bonds the pad to the caliper and piston.  You apply it and let the stuff kind of set up before applying a lot of pressure.  It works OK for the cars that I have owned that needed it.  No grease for the back of the pads, but for calipers that have to slide there is a special brake grease that I buy just for that.  Up here in Syracuse you have to use it on your car brakes or they will rust up and then not work.  I try to lube them up twice a year and that usually is enough to keep them working well.   Mike
Offline Madtownguzzi
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
« Reply #8 on: April 08, 2015, 06:35:34 PM »
Yes, that's the stuff that worked for me for almost a whole day,  It was red, as I remember.  A Permatex product maybe?  We followed the instructions to the letter, but maybe we just have stubborn calipers.
« Last Edit: April 08, 2015, 06:36:31 PM by Triple Jim »
