Author Topic: Stebel Nautilus on a Norge, Where will it fit.  (Read 12594 times)
Offline Idontwantapickle
« on: April 09, 2015, 06:12:48 PM »
Hello Norge People.
I bought a compact Stebel Nautilus for my Norge as the bleat-bleat horn is ridiculous. I saw a pic on Amazon of this horn mounted at the stock location on a CARC bike but when I hold it in that spot it's too close to the fender. I'm sure it will hit on a hard stop.
So I'd like some feedback on what others have done with this particular horn.
http://www.amazon.com/Stebel-Nautilus-Universal-Motorcycles-Scooters/dp/B00CMX20H4/ref=sr_1_1?ie=UTF8&qid=1428621303&sr=8-1&keywords=stebel+nautilus+compact+horn
Thanks, Hunter
« Last Edit: April 09, 2015, 06:15:35 PM by Idontwantapickle »
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline atavar
Re: Stebel Nautilus on a Norge, Where will it fit.
« Reply #1 on: April 09, 2015, 06:18:56 PM »
I am interested too, as I have just ordered one for my Norge.  I am tired of sounding like a scooter.
My plan is to make a mount up in the fairing some where, but I am waiting to get the horn before working it out.
Alternatively may be a custom brace across the timing cover using two bolts.
if you get yours mounted before I do post pics!   :PICS!:
Offline smdl
« Reply #2 on: April 09, 2015, 06:25:16 PM »
My Norge had one tied into the left-side coil mount.  It was dead (I hear that these things fail quite regularly), so I replaced it with a set of dual Fiamms, mounted in the same place, one on each side.
Cheers,
Shaun
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
« Reply #3 on: April 09, 2015, 06:52:39 PM »
Cheers,
Shaun
Me, too..
Offline Dean Rose
    • Twin Valley Riders
« Reply #4 on: April 09, 2015, 06:55:01 PM »
Me, too..
Got those on the EV need to put them on the Breva.
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Offline Adk.IBO
« Reply #5 on: April 09, 2015, 07:07:39 PM »
I can pull the appropriate panel off my Norge in the am, take a couple pics and see if I remember how to post them. It is so worth doing. It needs a relay also I believe. If there wasn't snow still in the driveway and salt on the roads.... it might be to late ;).
Stay safe, John
Luke 23:34
Offline old as dirt 2
« Reply #6 on: April 09, 2015, 07:42:31 PM »
I have installed a few of these in scooters and there you really have to be creative.
separate the horn from the air compressor, this make finding spots to mount each soon much easier. just run a small 1/4 " clear tube between them.
I plane to mount one on my Norge this coming week after I pick it up this weekend from Charlotte. I'll try and get some pics and what nots done.
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
Bill Hagan
« Reply #7 on: April 09, 2015, 09:28:55 PM »
I installed one several years ago.  Still works like a champ.
In fact, you have to be careful as it's so loud that some drivers over-react and over-correct right into your lane.   :o
FWIW, see http://share.shutterfly.com/action/welcome?sid=2ActHDdm5csXxw
The pix are bigger and the captions easier to read in "slideshow" mode.
Bill
Offline Adk.IBO
« Reply #8 on: April 09, 2015, 09:57:31 PM »
No need for me to take pics, that is exactly how I did mine! Thanks Bill! I'm sure you're where the idea came from! ;-T ;-T ;-T
Stay safe, John
Luke 23:34
« Reply #9 on: April 09, 2015, 10:06:50 PM »
Bill thanks for the pics and ideas where to mount the horn.
2013 Norge
2008 MP3 500
Offline Vagrant
« Reply #10 on: April 10, 2015, 08:01:05 AM »
I was all set to install one but now that I see Bill's pics and see that the oil needs to be drained at the same time I think I'll wait.
Bill Hagan
« Reply #11 on: April 10, 2015, 08:18:38 AM »
Actually, Steve, that is only needed when installing the base model of the horn.
Something to do with aligning harmonics and thermodynamic dissonance.   ;)
Bill
« Reply #12 on: April 10, 2015, 12:04:24 PM »
Thanks for all the responses and conversation on the horn.
Nice job on the mount there Bill but I wonder why a red Norge even needs a horn.  ;D
I did come up with a slightly different take on it from what BIll did. I mounted it on the right side (rather than left) in the space between the coil and the fairing. The reason for putting it here is that I wanted the outlets on the horn to aim forward and out so as to deliver what I paid for to the intended target.
I made a bracket from some inch wide strip aluminum in the shape of a giant fishing hook. I used aluminum since it is easy to shape and I had it already. When done I will use it as a pattern to make a steel one. The "barb" end of the hook is bolted to the upper right coil mount. The "line" end of the hook attaches to the main fairing mount frame on a tab right of the upper fork clamp. I took off the old horn and routed the wires back up to the top of the alternator and used them to trigger the relay. I attached the relay to the frame with a zip tie so as to keep everything rub free. Then a simple wire with fuse from the battery and wires to the horn and BLAMO my neighbors knew I had a new horn.
Here's another thousand words:
72 Eldo
84 BMW R100RS
« Reply #13 on: April 10, 2015, 02:59:12 PM »
One thing to be aware of, install the horn/s so it's self draining otherwise it will fill with water and just emit a pathetic squeak.
A pair of Fiaams do well IMHO
« Reply #14 on: April 13, 2015, 08:17:41 PM »
just fitted a stebel where the stock one was. just had to make an offset bracket is all. fit really nice between the frame tubes. sounds awesome
« Last Edit: April 13, 2015, 08:27:35 PM by old as dirt 2 »
2013 Norge
2008 MP3 500
Offline atavar
« Reply #15 on: April 13, 2015, 08:20:26 PM »
Just got my Stebel in the mail.  The thing is huge!  I will have to look tomorrow and see about making a bracket.
« Reply #16 on: April 13, 2015, 08:28:28 PM »
if I could figure outlaw to load pics I'll show you the one I made
2013 Norge
2008 MP3 500
Moto
« Reply #17 on: April 13, 2015, 09:51:48 PM »
Did you make sure you got the Compact Nautilus and not the regular Nautilus?
Regular: http://www.stebel.it/stebel/products.asp?IDserie=4&uso=&tipologia=ELECTROPNEUMATICS
Compact: http://www.stebel.it/stebel/products.asp?IDserie=6&uso=&tipologia=ELECTROPNEUMATICS
Offline atavar
« Reply #18 on: April 13, 2015, 10:34:41 PM »
yeah, it's the compact with the ports out the front.  i guess I'm just comparing it to the moped beeper that was stock on the bike.  lol  Why did they even bother putting a horn on the bike if that's all they were gonna do?
« Reply #19 on: April 14, 2015, 12:13:32 AM »
Here was my takeaway from their marketing materials (from the Stebel link)
"Your car horn has an extremely important function, try it and let yourself be hard!"
Direct quote.
Just what else does that horn do?
Maybe that is why it doesn't fit?
« Last Edit: April 14, 2015, 12:14:31 AM by Norge Pilot »
Offline Moto Fugazzi
    • Griso
« Reply #20 on: April 14, 2015, 01:26:22 AM »
I've had a Stebel for years on a previous bike, and I was told to never mount it upside down, or in any way that water would collect inside the horn (directly behind the tire). It's the water that kills them.
I still have the old horn, and I can't find a good spot to mount it on my V11S or V7C. A relay is recommended for these.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
Offline M0T0Geezer
    • The Ones I Rode
« Reply #21 on: April 14, 2015, 10:09:07 AM »
...separate the horn from the air compressor, this make finding spots to mount each soon much easier. just run a small 1/4 " clear tube between them.
Keep in mind that the longer the tube (air path), the longer the latency between when the horn button is pushed and when the horn actually sounds.  Keep the extension air tube as short as possible.
'Geezer
Wisdom from the road:
« Reply #22 on: April 14, 2015, 10:32:32 AM »
Make sure to check with the front suspension fully compressed. It gets really tight when you get on the brakes hard. Mine when fully compressed barely leaves room for my hand to fit in front of the engine. I did not want to break the fender, engine cover or horn much less bind on the wheel at an inconvenient time!
If you look at the ring of dust on the fork tubes after a really hard stop you can see and measure the travel. Now look at the position of the fender and measure away from it parallel to the fork tubes to get an idea of what the clearance would be when stopping hard or bottoming out. I cut a chopstick to the appropriate length and used it to gauge the clearance.
It's worth checking!
Hunter
72 Eldo
84 BMW R100RS
