Author Topic: Shorter rear shoks for convert  (Read 4554 times)
Offline gearman
« on: April 10, 2015, 11:17:49 AM »
What kind of shorter rear shock is available? I did a search and saw where Mtberio mentioned a 12.5 in on his vintage but I could find nothing on a convert. I am thinking I would have to lower the front forks also so as not to affect handling.
Re: Shorter rear shoks for convert
« Reply #1 on: April 10, 2015, 12:01:02 PM »
What's the issue with the stockers?
You might be able to move the upper shock mount point forward a little, which would have the effect of lowering the shock.  Maybe make a post on a piece of flat bar, drill the flat bar once to go over the bike's existing post, and then another for a second fastening bolt?
Be careful with shock length.  You can stress the ujoints and make the rear drive fluid migrate into the ujoint boot.
« Reply #2 on: April 10, 2015, 12:07:22 PM »
It will affect handling what ever you do.
Offline gearman
« Reply #3 on: April 10, 2015, 12:11:16 PM »
Rk, Since I have NPH my legs are not as strong as they should be. Exercise does not seem to help much.I thought that if I could be more flat footed  I would have more control.
« Reply #4 on: April 10, 2015, 12:13:52 PM »
You might also try shorter rims and/or lower aspect tires . . .
What is the stock length?
Offline gearman
« Reply #5 on: April 10, 2015, 07:49:24 PM »
The bike is stock. After I posted I went out for a ride and decided I may as well just get used to it. thanks all :)
