Author Topic: Small Block Drive Shaft Spring--Why?  (Read 6225 times)
Offline SmithSwede
  • I don't want a pickle
« on: April 12, 2015, 12:41:40 PM »
Changed the rear tire yesterday and greased the splines on rear of drive-shaft on 2013 Guzzi Stone.
Put it all back together, but now realize from studying the parts diagram that I reversed the order of the spring (GU94321099) and the plate.   Looks like the plate fits in front of the circlip on the coupling, then the spring fits between the plate and a hole at end of drive shaft.
Sigh.  I'll take it apart and do it right.   But does anyone know what exactly is the function of this spring?   Yes, I know, it pushes backwards...but why do we want that?
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Re: Small Block Drive Shaft Spring--Why?
« Reply #1 on: April 12, 2015, 01:11:43 PM »
Well, think a bout it. What does the "coupler" do? What will happen if it's free to move forward?  ;D
Offline SED
« Reply #2 on: April 12, 2015, 01:26:05 PM »
I think the reason is partly as a retainer and perhaps damp out a rattle. And it may keep the plunge joint wearing where they want it.  If the coupling sleeve had its disk fixed into it (with 2 circlips for example) the coupling sleeve would be permitted to move back and forth between the drive shaft and the spline on the bevel box, but it would probably rattle so you'd want a spring there anyway.  It may also dampen some chatter as the driveshaft spins and suspension moves up and down.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline steamdriven NZ
  • simplify and add lightness
« Reply #3 on: April 14, 2015, 03:44:21 AM »
The spring is important! It forces the driveshaft forward, keeping the centre of the universal joint concentric with the centre of the swingarm pivot. Remember that the female driveshaft spline forward of the UJ is a sliding fit on the gearbox output shaft (sliding forward until it bottoms out) , so it would also be free to move rearward except for the action of the spring keeping it pressed fwd into the output shaft. The driveshaft end is specifically drilled to take the spring to stop it cocking over.
I would imagine that having the two centres not being aligned could cause "some issues" considering the physics involved, with this thing doing a fair few revs as well as the gyrations with suspension movement and shock loadings when you hit a decent bump.
The spring acts on that disc keeping the coupler located on the pinion spline in its correct position too.
The first time I thought about all this I thought "Really? Thats' quite low tech" but hey it works well and has never been an issue that I have heard of.......
Kev.
« Last Edit: April 14, 2015, 03:46:25 AM by steamdriven NZ »
When you spend more time spannering than using, you have reached toy saturation.....
'84 750 Monza (The Monzada)
Offline kevdog3019
« Reply #4 on: April 14, 2015, 11:32:28 AM »
The spring keeps the coupler in place. To be more specific, it keeps constant pressure on the coupler retainer so that movement can't occurr.
« Last Edit: April 14, 2015, 11:35:38 AM by kevdog3019 »
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline sib
« Reply #5 on: April 14, 2015, 05:14:49 PM »
I haven't had mine apart yet, so please excuse the naive questions:
Where does the circlip (N) go? Is there a groove for it in the coupler (L)?  Or is there a groove in the bevel drive adapter fitting (P)?
Thanks.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline kevdog3019
« Reply #6 on: April 14, 2015, 05:51:59 PM »
Thanks.
Good questions:  There's a groove for the circlip in the coupler for the disc to sit against.
'86 V65 Lario
Offline sib
« Reply #7 on: April 15, 2015, 06:59:05 AM »
Kool, thanks.
