Author Topic: Norge mufflerectomy  (Read 4925 times)
Far star
Norge mufflerectomy
« on: April 12, 2015, 04:42:54 PM »
   I love my Norge, but it is not quite loud enough. Over 50 mph I can't hear the engine at all unless I'm hard accelerating. Then it is mostly intake sound. I have searched through the threads here and Guzzitech. Has anyone modified one and have photos of these mufflers apart? I realize I would likely need to change the firmware if too much is changed, which is fine. Yes I'm being cheap. I may buy an aftermarket anyway but would like to explore options.
Re: Norge mufflerectomy
« Reply #1 on: April 12, 2015, 05:25:52 PM »
I have a Staintune in the classifieds right now, $325.
Offline JeffOlson
« Reply #2 on: April 12, 2015, 05:31:17 PM »
That was my complaint about my Norge's muffler: it was too quiet.
However, I now have over 1,100 miles on my Norge, and the muffler is now noticeable and nicely louder. I do not know why, but it is.
Nevertheless, never content to simply let things be, I ordered an Agostini silencer from Italy. With the decibel killer in, it is quieter than my stock muffler. With the decibel killer out, it is a bit louder (but not obnoxiously so) than my stock muffler. (I say "my stock muffler" because, again, my muffler is now louder than it was when new.)
If you do not yet have many miles on your Norge, you might want to wait. If you do and you are not satisfied, then consider a Mistral or Agostini silencer, but only if you plan to ride it with the decibel killer removed. Otherwise, why bother?
Also, note that the Agostini silencer is MUCH smaller and lighter than the stock muffler, and it is oval-shaped, not round. These two features may be important to you. The Agostini silencer looks a bit odd on the Norge; the proportions are not quite right. Also, because it is oval, if you use your panniers, you will need to use the extension plate that lowers the silencer so it does to hit the left pannier. This in itself isn't bad, but because the Agostini is oval, and because it was designed to install without the extension plate, it will look like an italic O with the extension plate; it will be tilted sideways, and there is nothing you can do to straighten it. (I understand the Mistral is round, not oval, so this would be a better choice if that bothers you, as it does me...)
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #3 on: April 12, 2015, 05:44:25 PM »
I'm wondering if my stock Lafranconis originally had packing that has disintegrated and blown out.  They aren't what I'd call quiet.
« Last Edit: April 12, 2015, 05:44:37 PM by Triple Jim »
Offline roofus
« Reply #4 on: April 12, 2015, 05:47:33 PM »
I replace the stock Norge muffler with a Mistral . . . .better sound . . . .better performance . . .and I dropped a few pounds in the process!!!!
Far star
« Reply #5 on: April 12, 2015, 10:06:40 PM »
Thanks for the replies. Not sure what I'm going to do yet. The feedback helps. If I do surgery on mine I'll post pics.
Offline JeffOlson
« Reply #6 on: April 12, 2015, 10:36:31 PM »
There's a guy on YouTube who did surgery to his (older) Norge silencer, but it required a bit of welding and fabrication. Basically, he removed all the crap from the internal part of his muffler and welded in a two-foot long tube with holes in it, wrapped in fiberglass...
2018 Vespa GTS 300
2015 Vespa GTS 300
