ABS is a deal breaker for me to ever own any bike. I owned three different models of BMW's with different ABS systems and every one of them broke and cost a lot of money to fix. Two were out of warranty when they broke and BMW had to eat the other one. It also adds weight and complexity; two things I specifically don't want on any motorcycle.
They're going to have to change the gear ratios if they want the rider to get any real use from a six speed tranny. I don't ever get beyond fourth gear and won't unless I were on an interstate hwy driving 80 mph or more. It may turn out to be great but I have no beef with the tranny that was used in the Breva and my V7. ABS is a deal breaker for me to ever own any bike. I owned three different models of BMW's with different ABS systems and every one of them broke and cost a lot of money to fix. Two were out of warranty when they broke and BMW had to eat the other one. It also adds weight and complexity; two things I specifically don't want on any motorcycle.
There is another option:Buy a used Breva 750 or Classic 750 right now (prices are very low) and trade it in on a new V7-II this fall... IFF you can still find a logical reason for doing so.'Geezer
As for ABS I've had one BMW (R1100RS) and one Ducati (M696) with it, and though I was reluctant to embrace the tech on bikes I have to admit both systems have been flawless and not required any repairs.
Here's a biased opinion based on incomplete information. Unless I hear really glowing reports about the newer Stones, they won't tempt me from my 13 model Stone with single TB. I find the 5 speed transmission brilliant. Can't really see how you would improve it with another gear. The engine is so torquey and fun, that it's an *advantage* not to fuss around with gear choices. And as for high speed cruising, I suspect the engine really needs to spin a bit. I'm turning about 5,000 rpm at 80 something, which feels right. And it's not like you need another gear so you can avoid a bad, vibey rev zone. So 5 gears seems like a feature, not a bug. I've got very mixed views about ABS. At least on my BMW F800, it seems to have as many downsides as upsides. Yes, I suppose it could save a skid on wet leaves or something. But over bumpy pavement, the dang thing activates when not needed, substantially increasing stopping distance. I've ridden the same route on my daily commute for years. There are sections of bumpy pavement leading up to various stoplights and crosswalks. On my Guzzi and Ninja, I can brake aggressively, and while the front might get chirpy, I stop rapidly. On the BMW, the ABS cuts in and I go sailing far past my intended stopping point. Maybe that's just an issue with BMW ABS and the Guzzi system would be better. But I personally don't view ABS as a must have. And there's no denying the complexity and expense if the thing goes wonky.
This ;-T 100%The 5 speed tranny is fine and shifts smoothly for the 4 I've owned from '86-2004.
Buy the latest and put some 4 valve heads on it. :P ;-T ;D
Kev, I wasn't aware that the STB would allow the engine to run more comfortably at lower rpm's than the DTB models. Good info to know. Thanks!jas57, one of my ABS Beemers that failed (to the tune of what would have cost me over $2k to repair had it not still been under warranty) was a 2002 R1150RT with the goofy brakes. Another one that failed had the prior generation of ABS (R1200C) and the first one that failed was on a BMW K-bike. To each his own but I refuse to buy any motorcycle with an ABS system or too many complex "do-dads". (am I'm a high-tech type who normally loves tech gadgets). Just not on a motorcycle.
