Author Topic: 2009 Stelvio Aux Lights Not Working From Handelbar Switch - Fuse or ? - See pics  (Read 3371 times)
bmacneil2008
I have had my 10w aux lights wired to the fog lights, the small bulbs next to the headlight, and all perfect. Did not see the aux light switch on the right controls and also saw the connectors on the left and right under the cowling.
Probably dumb as I look.
Anyway, though a forum member I ordered the matching female connectors and wired all up but nada, zero, zilch.
Started the bike thinking that may be the issue, still nothing. Any thoughts?
So, now thinking would be easiest to plug back in to the fog lights and wondering if anyone knows where I can get the same connectors as I do not see available to order on Harpers. I can make a three way (no giggling) harness.
I found SS sleeve and taped the ends and then shrink wrapped. Looks great but total poser lights at the moment :)
Thanks.
Online Wayne Orwig
A. That connector looks like the heated grips connector, not the fog light connector. BUT, it was almost 6 years ago when I wired mine up, so I easily am wrong.
B. Mine did NOT have a relay in the relay block. The gray cover, inside the fairing, on the right side. I had to add the relay.
bmacneil2008
Great, thanks. Same reply from others. I took the fairing off once and really do not want to do again. Can be done w/o removing and I assume order the relay from the dealer?
Online Wayne Orwig
It can be reached without disassembling anything. You need a SMALL hand though.
The relay has a match for the ones in my EV, and I had a pile of spares from DPGuzzi.com.
bmacneil2008
Good to know. I had to take off the fairing to remove the ECU for a reflash and was a 100% pain. What is the relay called specifically, "Auxiliary Light Relay"? Thanks.
