Author Topic: turn signal relay  (Read 4904 times)
Offline rudyr
turn signal relay
« on: April 21, 2015, 08:06:55 PM »
lost my owner's manual that's makes 3.  back to Harper's for a 2000 Jackal owners manual and moley for rear end.  but for now where is the relay location on the fuse board. rudyr
Re: turn signal relay
« Reply #1 on: April 22, 2015, 01:58:52 PM »
It's not on the fuse/relay boards.  It's more-or-less standalone.  Exactly where I do not remember.  Someone will be along to help with the location.  Or you can turn on the turn signal and follow the clicky noise to its source.
« Reply #2 on: April 22, 2015, 02:16:51 PM »
If you're looking for the fuse it should be listed inside the RH side cover.
Here you go, Carl to the rescue. fuse 2
http://www.thisoldtractor.com/guzzi007/schematics/2000_Jackal.gif
If your flashers aren't going check for voltage at fuse 2 and get back.
« Last Edit: April 22, 2015, 02:27:08 PM by Kiwi_Roy »
Offline rudyr
« Reply #3 on: April 24, 2015, 07:13:08 PM »
Well F2 fuse is counting from the back of the fuse bock forward.  And it dose feed the flasher out of the ignitiion switch.  no power out of the switch to flasher then to the left handel bar turn signel switch.  Now I'm going to get into the Igition switch and see what I find. Rudyr
« Reply #4 on: April 24, 2015, 07:30:12 PM »
If fuse f2 lights up a test light on both sides the ignition switch is good.  Or, tracing the diagram -- if the tail lights work the fuse and ignition switch are good.
Offline rudyr
« Reply #5 on: April 24, 2015, 08:55:53 PM »
I have no power(12V) on either side of F2 fuse.rudyr
« Reply #6 on: April 24, 2015, 09:23:08 PM »
understood.
