Author Topic: Convert question....  (Read 4164 times)
Offline nilo
« on: April 29, 2015, 08:56:48 AM »
Hi there,
¿¿¿¿  How would I block the engine to loosen the alternator bolt   ????.
Thanks in advance for any insights......
´81 Convert,R80GS,XL200,Dnepr MT11,Moto Morini 350 Kanguro
56Pan
Re: Convert question....
« Reply #1 on: April 29, 2015, 09:37:02 AM »
Nilo,
  If it was me, I would use the rope trick.  Get some clean rope, take out the spark plug on one of the cylinders. Put a thumb over the spark plug hole and get that cyl. with the piston at the start of the compression stroke.  Feed the rope into the plug hole and then slowly rotate the engine until the piston compresses the wad of rope against the top of the combustion chamber and the closed valves.  Of course, leave plenty of rope hanging out the plug hole.  It's always worked for me.
« Reply #2 on: April 29, 2015, 09:46:15 AM »
Remove the rubber plug from the timing hole on the right side, use a small prybar or flat-blade screwdriver to engage the ring gear teeth.
Offline Larry Wiechman
« Reply #3 on: April 29, 2015, 11:20:21 AM »
 Use a pneumatic impact gun. It hits so hard and fast, there is no need to lock the crank.
1977 Convert
1978 LeMans
1982 Honda Ascot FT500
1983 Honda XR500R
1983 Honda XL600R Supermoto
1992 Honda XR100R
1989 Kawasaki KX500
2015 KTM 1290 SD
2017 KTM 500 EXC
Offline mtiberio
    • TiberioRacing
« Reply #4 on: April 29, 2015, 12:23:18 PM »
all 3, or just try to use a hand wrench, it may come loose.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #5 on: April 29, 2015, 12:43:07 PM »
drop sump, block of wood to jam crank.
Offline nilo
« Reply #6 on: April 29, 2015, 01:13:41 PM »
Wow, thankyou so many good ideas......especial ly the rope trick.
It did actually just loosen up with a spanner against the compression of the engine.
un saludo a todos....
Offline mtiberio
    • TiberioRacing
« Reply #7 on: April 29, 2015, 04:58:39 PM »
And the weiner is...
