Author Topic: AUXILIARY LICENSE PLATE STOP LIGHT  (Read 6255 times)
Offline Spuddy
« on: May 04, 2015, 10:39:41 AM »
I'm looking for an inexpensive (not cheap) LED auxiliary stop light for my '13 Stelvio. Given the lack of mounting options it seems a license plate frame with an integrated light bar is the way to go.  Any experiences or suggestions?
'13 Stelvio NTX
'07 California Vintage
'01 W650
Offline Gootsz
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
Re: AUXILIARY LICENSE PLATE STOP LIGHT
« Reply #2 on: May 04, 2015, 12:05:10 PM »
http://wildguzzi.com/forum/index.php?topic=76121.0
Inexpensive, easy to wire in and isn't yet another thing hanging off the back of your bike.
« Reply #3 on: May 04, 2015, 01:36:05 PM »
I spend hours looking over the colors, shapes, and sizes of LEDs.  It's getting to the point that you're limited by imagination more than anything else.  Have you considered the little button LEDs with screw stud mounts?  They'll replace your license plate bolts and give you a brake light on each corner.
Offline Mark West
« Reply #4 on: May 04, 2015, 06:29:09 PM »
The problem with a lot of these is they have so little light, they get lost. For a brake light, you want something that stands out. I had Hyper lights and they were ok at night but during the day were not very noticeable.
I put an 1157 bulb that was 1W running and 5W brake and that made a huge difference. Way brighter than stock.
Mark West
Hollister, CA
MGNOC L-752
« Reply #5 on: May 05, 2015, 04:56:46 AM »
The ones I ordered are supposed to be 3w.  I'll let you know if they're bright or not.
« Reply #6 on: May 05, 2015, 08:22:28 AM »
The ones you want are usually called super light.  The little LED's will be square, not round.
3W should be plenty.  "Driving lights" are 10W.
redrider
« Reply #7 on: May 05, 2015, 09:27:33 AM »
I just installed the 16 LED Hyperlights. Two modules in the kit. Daytime running with 5 seconds of BRIGHT flashing then solid. Did I say these were BRIGHT? Retina burners and most folks stop 2-3 car lengths back in the daytime.
Offline twhitaker
« Reply #8 on: May 05, 2015, 10:50:31 AM »
Aerostich has a nice license plate brake light.
http://www.aerostich.com/stopper-led-brake-light-stopper.html
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #9 on: May 05, 2015, 11:06:36 AM »
I like that version, and the other one that serves as park and turn signals.  Neat solution.
I am one that cannot have too many lights on the bike.
Offline jreagan
« Reply #10 on: May 05, 2015, 12:10:29 PM »
"Loud Valves Save Lives"
2004 Triumph Bonneville T100
2006 Breva 1100 (red)
Nicholasville KY USA
« Reply #11 on: May 06, 2015, 10:29:47 PM »
Got my amber button lights in.  Seem to be well made -- metal posts and some sort of bulbous yellow lens.  I was surprised by the heft.  I'll give them some battery tonight and see what they look like.
Offline Spuddy
« Reply #12 on: May 08, 2015, 11:29:27 AM »
I shudder what may happen when I tap into those TINY gauge wires leading to the stock stop and running lights. Ya think red crimp ons will work? What does any else use?  I need some hand holding.
'13 Stelvio NTX
'01 W650
« Reply #13 on: May 08, 2015, 11:32:07 AM »
Get the correct size of these things.  They work as well as you can for a tap without splicing the wire.
http://www.posi-products.com/posiplug.html
« Reply #14 on: May 08, 2015, 01:31:25 PM »
If you take your good stripper/crimpers you can score the wire insulation with quick twist around it.  Then gently use the still-closed stripper to break the insulation at the score.  Make another score about 3/8" away from the first one.  Shave between them with an exacto knife and pull the insulation away.  Now you have a 3/8" bit of exposed wire.
Do a wrap connect of the pigtail you want to splice and solder it.  Re-insulate with tape or (preferred if you can get it on the wire) shrink wrap.
I did a test of the little 3w button lights.  They are as bright as a regular turn signal, but they do not have the wide, scattered beam of a proper turn signal -- narrow viewing angle.  I had anticipated this and ordered two per corner -- one to face forward and one to face sideward.  They will do.
