Author Topic: WTB - Norge tail light connector  (Read 3425 times)
Offline atavar
« on: May 04, 2015, 09:16:45 PM »
I am installing the light kit in my Givi top case.  I would really like to find a connector pair to make an adapter instead of hacking in to the wiring harness to add a diode.
Does anyone have a dead/wrecked Norge they could cut the connector out of leaving some inches of wire for soldering to?
Alternatively do you know of part numbers and a source for the connectors?
TIA, Please IM me or reply here if you can help.
Offline atavar
Re: WTB - Norge tail light connector
« Reply #1 on: May 04, 2015, 10:32:32 PM »
I think I found the connectors and pins at digikey.  About $40 for enough to make two adapters.  Ouch.
If I do order these would anyone else like a plug-and-play insertable (no cutting stock wires) adapter with outputs for brake, tail and brake/tail signals?  Your cost would be like $20 plus shipping, actual cost, no profit.
Here is a link to what I am thinking of ordering..  http://www.digikey.com/short/7wdnm3
Offline atavar
« Reply #2 on: May 22, 2015, 06:42:14 PM »
Completely different connector.  These are three pins only.  I did get the ones from DigiKey and they worked great!  The Givi connectors used for the installation are a PITA though, they have to be aligned perfectly.
Offline Idontwantapickle
« Reply #3 on: May 26, 2015, 03:10:44 PM »
I took the link off to avoid confusion that you refer to here. The OBD connector on my Norge is the same 3 pin connector as the tail light and ABS interface.
Ordered the goodies you so kindly listed from Digikey.  ;-T  Can't wait to hook my extra brake light!
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline atavar
« Reply #4 on: May 26, 2015, 05:23:13 PM »
The only caution I make is to ensure you are putting the right pins in the right holes on the connectors.  The pin removal tool costs more than the connectors.
