I'm surprised he wants to use the flash function, I thought that was a European thing.
I guess the designer thought that High beam was normal. You could switch it over or add a pair of diodes so that both beams light up even if the lights are switched off.Update:Sorry, the schematic is too blurry to work with but you are correct the flash relay goes to the low beam.It might be a little hard to switch the green wire over to the high beam (from 6 to 5 at the 12 way terminal strip)I'm surprised he wants to use the flash function, I thought that was a European thing.Update: I looked at several other schematics, the relay called "High beam Flash Relay" is always wired to the Low beam filament, that's Luigi for you ;D
Flashing the low beam was the intention of the original design since it was not required to have the light on during the day in much of the world back then..
Yes, it's obviously intentional, although it does seem strange. I remember that the 70s era Honda's I used to own had the flash to high beam., and I thought all motorcycles (and cars) were set up that way. JohnSent from my iPad using Tapatalk
Guzzis of that era are the only ones I can recall being that way. Here in the states they were wired for the lights to stay on all the time. Many were "fixed" so that the lights could be turned off for starting, servicing etc. But on those bikes unless someone changed the flash wiring to the hi beam all you would get was a tiny bit brighter low beam.I hope your friend enjoys that Guzzi. It's a great bike to ride as intended!
In days past, the 'high' beam was the driving lamp, and the 'low' beam was the PASSING LAMP. (ever wonder why the old guys call the footswitch in your old car the 'dipswitch'?) You drove on the most powerful lamp, and dipped it to low beam when you passed ONCOMING traffic. Not particularly helpful, **C
