Author Topic: Fork Brace?  (Read 2823 times)
Offline StuCorpe
Fork Brace?
« on: May 08, 2015, 06:28:06 PM »
Does anyone know of a stiffer (heaver duty?) fork brace available for a 2003 EV?  Since I put the sidecar on I occasionally (at low speeds  >10mph) get a front wheel wobble ???.  Only happens at low speeds and certain bumps in the road.  Thought maybe a stronger front fork brace might help.  I remember putting one on a Yamaha Venture Royale for the same problem and it took all the low speed shake out.  Just looking for ideas.  Tried tightening the steering damper down but I think it's worn out as it made absolutely no change.
Any other ideas would be appreciated.
Offline Silver Goose
Re: Fork Brace?
« Reply #1 on: May 08, 2015, 07:38:23 PM »
Stu, look into a hydraulic damper. Severial sidecar companies offer them, but if push comes to shove, look at a sterring damper from a import truck and many small cars. Also check the sidecar alignment.
I have owned three sidecar bikes and getting a hydraulic damper and the proper alignment will make a great ride, better.
Good Luck
2007 Norge
2002 BMW K1200 LT
1959 Indian/enfield
1964 Norton
2008 Can Am Spyder
Offline racasey
Re: Fork Brace?
« Reply #2 on: May 09, 2015, 02:12:11 AM »
Sidecars demand steering dampers.  Popular options are either a VW Beetle hydraulic damper, or a damper for a Mercedes 190.  They are inexpensive, and long lasting.  Typical installation places the damper outboard of the lower fork yoke to a location near the bottom of the forward top strut.
Ciao,
Dick Casey
84 V65
1090RR MV Agusta
Paul Smart Ducati
'66 Velocette Thruxton VMT 334
'63 Aermacchi 250
Seeley MK-III AJS 500
Offline StuCorpe
Re: Fork Brace?
« Reply #3 on: May 09, 2015, 07:30:00 AM »
Thanks, I will start checking these out. :)
