Author Topic: Check Those V7 (smallblock) Tank Rubber Bolts  (Read 3382 times)
Online Cam3512
« on: May 10, 2015, 05:07:22 PM »
Last year Pete created a post regarding loose tank rubber bolts wearing a hole in the underside of the tank, but I can't find it.  I finally pulled my tank back (new centerstand helped) to check mine.  Sure enough, the left side was VERY loose.  Right was still tight.  I Loctited both and re-greased the rubber pucks for good measure.  Easy job, and doesn't take long.  Check yours' out!
Cam
« Last Edit: May 10, 2015, 05:07:50 PM by Cam3512 »
Offline organfixsing
Re: Check Those V7 (smallblock) Tank Rubber Bolts
« Reply #1 on: June 03, 2015, 05:55:20 AM »
I think this may only apply to the plastic tanks. I have a V7 II with a metal tank and I looked for the doughnuts like they were on the BREVA I had. No doughnuts?
Cheers
Brian
If you remove the wings of a fly, does that make it a walk?
« Reply #2 on: June 03, 2015, 06:00:58 AM »
Cheers
Brian
No the 2TB and earlier 1TB metal tanks (like Cam's and mine) both came with donuts. I checked and Loctited mine (I forget, but I think both were tight).
« Reply #3 on: June 03, 2015, 06:04:14 AM »
Nope. It was a metal tank bike but a loose bolt, (Not the puck.) will wear through plastic or steel with equal alacrity.
LaGrasta
« Reply #4 on: June 03, 2015, 11:03:21 AM »
I remember the original post, checked mine then and they were good. A few months later I was in there and sure enough, one was completely missing! I replaced it with a Honda puck and a Phillips button-head screw that I hand laying around. Then a few weeks later what should come falling out of the engine area, that missing puck!
« Reply #5 on: June 03, 2015, 11:06:13 AM »
I don't see how it could fall off with the tank in place without having bored a hole in the tank?
« Reply #6 on: June 03, 2015, 04:20:08 PM »
The only thing I can think of is that it became dislodged during tank installation, ironically when the tank had been removed to check the pucks.
