Author Topic: Location of 850T rear brake light switch  (Read 4767 times)
tenelson
« on: May 13, 2015, 10:41:15 PM »
My 850T did not come with a rear brake switch, which is not ideal for safety reasons. I'd like to install a switch, but I don't know where it mounts. Does anyone have a photo of the rear brake switch mounting setup on the 850T?
Offline JoeW
    • The Guzzi Doctor
Re: Location of 850T rear brake light switch
« Reply #1 on: May 13, 2015, 11:39:58 PM »
I don't have a photo handy but, it hangs from a right angle bracket that is attached to the left battery tray to frame bolt. It's a pull switch that is linked to the brake linkage by a spring. It's not easy to find in the parts manual or in the parts bin. I think it's NLA.
Joe Walano
Offline Two Checks
« Reply #2 on: May 14, 2015, 05:59:33 AM »
With a T you will be using the front brake anyway so the brake light will be lit. Trust me on this.
1987 1000 SPII "Il Duce' II"
Offline Testarossa
    • Skiing History
« Reply #3 on: May 14, 2015, 07:29:28 AM »
Two Checks is right. My switch spring broke decades ago. But if you need one to pass an inspection, Emco makes a pull switch for old Triumphss that could be fiddled to work.
tenelson
« Reply #4 on: May 14, 2015, 07:56:06 AM »
Ok, I can visualize that. Sounds like I need to start scouring eBay for a used part plus the bracket. I mostly use the front brake, but for slow speed stuff around town, I use the rear brake more. Which is where I'm more worried about getting rear ended.
Offline Idontwantapickle
« Reply #5 on: May 14, 2015, 09:12:28 AM »
 :+1
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Late to the party
  • 1987 1000 SP2
« Reply #6 on: May 14, 2015, 09:23:58 AM »
I'm redoing an 850T as well. The original rear brake switch corroded and fell off years ago. However, looking at where it mounts (down below, underneath and behind), I didn't even bother looking for an OEM switch. As has been mentioned, a standard,  weather-proof pull switch will do the job.
Lateness.
« Reply #7 on: May 14, 2015, 09:35:32 AM »
Both pieces you need are the same as on a late V7 Sport. The original switch, part no. 1474 1110, looks like this:
The mounting bracket, part no. 1474 2900, is an "L" shaped piece.
You might check with Harper's to see if they have them.
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
