Author Topic: Alternative risers for tube style bars  (Read 3096 times)
« on: May 14, 2015, 05:36:54 PM »
While there are sometimes sources for risers, they often aren't inexpensive, there is another way to make them yourself some.
The trick I used on my ST1100 was to get an extra set of bar clamps and simply turn them upside down, put the bar on and then the top clamps. Works like a charm on most bikes. The amount of rise you get varies but lots of times it is enough. All you need are longer bolts but they too are easy to get.
Its easy to check if this will work, just take the bolts out of the top clamps and raise the bar enough to put the top clamps underneath upside down. If they fit, all you need is an extra set.
One benefit you get is a space between the upside down clamp and the bottom one through which you can route wires if you have that need. Its an easy way to keep things tidy, just sheath them so they don't run on any sharp edges.
Offline JeffOlson
Re: Alternative risers for tube style bars
« Reply #1 on: May 14, 2015, 11:16:26 PM »
Nice idea!
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #2 on: May 15, 2015, 12:57:06 PM »
Then, there's the Old Skool socket solution to taller risers:
« Reply #3 on: May 15, 2015, 01:30:52 PM »
See?  Harbor Freight tools work good!
Offline JeffOlson
« Reply #4 on: May 15, 2015, 03:42:35 PM »
Ha!
2018 Vespa GTS 300
2015 Vespa GTS 300
