Author Topic: EV Not Charging  (Read 4934 times)
EV Not Charging
« on: May 21, 2015, 10:15:09 AM »
Coming back from a camping trip I stopped beside the road, when I tried to start again nothing, just the faint click of the relay, the headlight was showing sign of low Voltage. I unplugged it under the bucket to avoid any further drain.
Luckily I was stopped on a hill so bump starting was easy.
After running for a few miles I tried the starter again, nothing
I had to stop for gas so I took the opportunity to give the wiring the once over
There is no charging fuse on this bike, the red wire goes straight to the battery.
This is the bike I nursed back from Denver with a charging problem I replaced the regulator then so it's about 3 years old.
Inspected the yellow wires at the alternator, look ok and I got a circuit using my trouble light.
It has the extra ground to the case.
I concluded the regulator might be missing a reference so I hot wired the black wire (male pin) directly to the battery.
Got a push start and I was away.
Later on I tried the starter again, this time it worked so I assume my hot wire fix worked.
When I get a chance I will try to figure out what really happened and get back, in the meantime the bike is sitting all covered in mud in disgrace.
I think it might be pissed off that the Cali II got new tires the other day and it didn't ???
I took a bit of care installing the new regulator when I got the bike back home from Denver a couple of years back
I'm not in any rush to get this fixed, I would rather find an explanation, I will put the wiring back to stock and go from there.
« Last Edit: May 22, 2015, 04:45:38 AM by Kiwi_Roy »
Re: EV Not Charging
« Reply #1 on: May 21, 2015, 10:33:43 AM »
I think it might be pissed off that the Cali II got new tires the other day and it didn't Huh
Well, there ya go. Problem solved.
Offline twhitaker
Re: EV Not Charging
« Reply #2 on: May 21, 2015, 10:56:44 AM »
Anthropro.....Here we go again saying inanimate objects have feelings. They don't, corporations do.  ;D
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Bill Havins
Re: EV Not Charging
« Reply #3 on: May 21, 2015, 11:40:52 AM »
Roy,
Does the regulator normally get its reference off of the NO pin (87) of the headlight relay?
Bill
Re: EV Not Charging
« Reply #4 on: May 21, 2015, 06:08:24 PM »
Roy,
Bill
Yes, the headlight was on though
I haven't had a chance to look into it.
Since I give out lot's of advice I'd better be able to fix it eh!
Re: EV Not Charging
« Reply #5 on: May 21, 2015, 06:22:40 PM »
Amusing aside to fixing it --  Yesterday I went in to see my doctor RE: a respiratory virus.  Today my doctor saw me RE: computer virus.  Why yes -- the bills WILL match.  Thanks for asking.   ;D
