Author Topic: V7 Sport Ignition removal from housing (pin not moving)  (Read 3065 times)
Offline earemike
  • Lurker
« on: May 21, 2015, 09:46:52 PM »
Hi all,
I'm flummoxed as to how to shift the pin illustrated to remove my original ignition switch from the housing. The lock mechanism is frozen so while I could hope that freeing the tumbler would do the trick I have no idea if it's relevant.
Hints & tips greatly appreciated.
Thanks,
Mike
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Re: V7 Sport Ignition removal from housing (pin not moving)
« Reply #1 on: May 21, 2015, 10:35:29 PM »
You need the ignition key, as you turn the key, can't recall which of the three positions, but I think the second or running position and then press the pin it will depress sufficiently to allow the cylinder to pull out of the cast body.
Offline earemike
  • Lurker
« Reply #2 on: May 21, 2015, 11:06:34 PM »
Thanks mate,
looks like I'll keep lubing the key and working it everyday...
Appreciated,
Mike
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Online JoeW
    • The Guzzi Doctor
« Reply #3 on: May 22, 2015, 09:55:23 AM »
That pin is just an anti theft thing. I've ground it down with a dremmel. The 2 screws hold it in place.
Joe Walano
