Author Topic: Breva 750 Neutral Switch Replacement  (Read 3428 times)
Offline MikeW
    • Mike's Machines
« on: May 22, 2015, 01:27:54 AM »
Hi Guys,
Just wondering what's the best way to replace the neutral switch on the Breva 750?
It looks way more difficult than early model small blocks, there is just so much junk in the way! It looks to me like the whole airbox/breather assembly needs to come out along with the battery floor plate to gain access to the neutral switch.
Cheers!
Mike
Mike's Machines on You Tube
Motorcycle News & Reviews
Motorcycle Service Videos
Re: Breva 750 Neutral Switch Replacement
« Reply #1 on: May 22, 2015, 03:56:57 AM »
Easier way is just take off RH throttle body.
Offline sign216
« Reply #2 on: May 22, 2015, 07:28:50 AM »
Mike, after you're done, write up some tips for the rest of us.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline MikeW
    • Mike's Machines
« Reply #3 on: May 22, 2015, 11:51:13 PM »
How does removing the RH throttle body help?
The neutral switch further back in line with the swing arm pivot.
Mike
« Reply #4 on: May 23, 2015, 05:25:05 AM »
Gives you room to get your hand in there and remove it w/o cutting up your wrist.
