Author Topic: Footpegs Springs (Grrh!)  (Read 3795 times)
Offline JeffOlson
« on: May 23, 2015, 02:18:36 PM »
Okay, what's the trick?
I swapped out the front foot pegs on my Norge, and for the life of me I cannot reinstall the d#%* springs. I think I need some sort of cupped or bent tool to jam behind and under the spring to pull it away from the bike to be able to slide the pin through it.
Any advice?
« Last Edit: May 23, 2015, 02:23:03 PM by JeffOlson »
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Offline toma nova
Re: Footpegs Springs (Grrh!)
« Reply #1 on: May 23, 2015, 08:25:41 PM »
I just swapped on Goldwing pegs on the Stelvio (about an inch lower, longer, wider, etc.) and did not have any issues.
I started the pin through the front tang then pushed down on the spring to align it and pushed the pin in the rest of the way.  A little wiggling of the peg made everything line up.  In other words, put the spring into the slots - since it is uncompressed, it will be sticking up significantly.  Start the pin then push the spring down in between the peg tangs, compressing it.  Slide the pint he rest of the way through.
HTH,
2014 Stelvio NTX
2008 1200 Sport - sold
« Reply #2 on: May 23, 2015, 08:59:33 PM »
 Try learning to swear in Italian.
Online radguzzi
« Reply #3 on: May 23, 2015, 09:26:43 PM »
Jeff,
As I recall you just assemble the peg with the spring in it and push the pin through while holding tension against the back side of the spring into a detent and your in.  You do need to hold your tongue just right though... ;)
A bit difficult to explain, I'll take a shot of the Stelvio peg spring in the morning and post it for you.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline JeffOlson
« Reply #4 on: May 23, 2015, 10:39:40 PM »
Thanks, guys! I'll give it a try (especially the cursing in Italian part!).
2018 Vespa GTS 300
2015 Vespa GTS 300
« Reply #5 on: May 23, 2015, 11:18:12 PM »
I'm going to attempt to post one more time.  Make sure the dowel will fit into the foot peg mount.  Hold the spring in place using the wooden dowel to keep things aligned.  Hold the peg in the mount and tap the pin through, displacing the wooden dowel.  It works for me.
Offline JeffOlson
« Reply #6 on: May 23, 2015, 11:53:58 PM »
Cool! Thanks!
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline JeffOlson
« Reply #7 on: May 28, 2015, 10:36:27 AM »
And Bob's your uncle!
I tried Ohiorider's suggestion last night, and it worked like a charm. Extraordinarily easy! Thank you for the great suggestion!
Add to Moto Guzzi toolkit: wooden dowel; saw; circlip pliers; hammer...
2018 Vespa GTS 300
2015 Vespa GTS 300
