Author Topic: 03 Stone Axle Diameters / Bearings  (Read 2860 times)
Offline saguaro_squeezer
  • Lead, follow or get out of the way!
« on: May 25, 2015, 04:28:13 PM »
I've got an '03 Stone Touring that I've recently hung a Sputnik sidecar on and am wanting to replace the Sputnik wheel with a wheel of the same type as the Stone - either front or rear.  Does anyone have the bearing size (ID for the axle and OD for the wheel) for the front and rear wheels?  The Sputnik has a 17mm axle and I'm hoping to just change the bearings.
Rod Wagoner
Tucson, AZ
'03 Stone (Hydro) Touring / Sputnik Sidecar - Paola
MGNOC #22081
"How great life is if you just accept the small gifts and don't waste time on wishes." - Clinton "Bubba" Hare, Airheads Beemer Club
"OOP-ACK-THHPT!" - Bill the Cat
Re: 03 Stone Axle Diameters / Bearings
« Reply #1 on: May 25, 2015, 06:03:46 PM »
If you get the bearing #, say off MG Cycles site and do a search, you will find the ID & OD from mfg specs.
Offline Hahnda
    • Scrambler Cycle
« Reply #2 on: May 25, 2015, 07:04:28 PM »
Front and Rear - #92204220 20 mm ID × 47 mm OD × 14 mm wide
6303 bearing will have the 17mm ID, 47mm OD and 14mm wide.
1949 GTV - 1948 Airone
www.scramblercycle. com
« Reply #3 on: May 26, 2015, 02:43:46 PM »
Thanks, gents, for your advice.
Rod Wagoner
Tucson, AZ
MGNOC #22081
