Author Topic: Stelvio front wheel bearing number and rear wheel bolt torque...?  (Read 4141 times)
Offline radguzzi
In putting new sneakers on the '09 Stelvio and I discovered that I need front wheel bearings, unless the new style bearing is one that the inner race does not spin...  :o
The axle came out hard also, found it dry and slightly corroded.  Odd too as I bought the Stelvio from Phoenix which is very dry and the seller told me that he bought it from a fellow in Colorado.  Someone did not do a great job of protecting that front wheel.  I will though... ;)
So, couple of questions...
1. - I cannot find a part number for the bearings.  Anyone here have that info...?
2. - In the splendid list of torque values for e.v.e.r.y thing on that motorcycle in the T/M, Is the torque for the rear wheel bolts the value stated in the Stelvio T/M as the "Rear Wheel 10.9 - 110Nm...?
3. - Is it ok to use the gearbox to hold the rear wheel in place while I torque the rear wheel bolts...?  Should I use the brake instead...?
Thanks,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Re: Stelvio front wheel bearing number and rear wheel bolt torque...?
« Reply #1 on: May 25, 2015, 07:11:56 PM »
Rob,
Front Wheel Bearing # AP8125777        25x47x12
Torque is 80ftlbs on 4 back bolts
I use both in 1st and a bungie on rear brake
Offline radguzzi
« Reply #2 on: May 25, 2015, 07:26:52 PM »
Steve,
Schweet, where did you find the P/N data...?
Copy that on the bungie, I employ the assistance of my Wife when she is available.   ;D
Thanks very much.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
« Reply #3 on: May 25, 2015, 07:28:31 PM »
Right out of the parts man here on my puter.
Offline radguzzi
« Reply #5 on: May 25, 2015, 07:56:50 PM »
Thank you Steve, I was just going to looking for that...
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
