Author Topic: New to Guzzi -questions & observations...  (Read 6030 times)
Offline Chuck-D
« on: June 02, 2015, 11:12:15 AM »
 I just picked up a new V7 ii Stone from the local dealer. It's my first big-boy bike, I've put about 20 miles on it, and have some observations:
- This is a LOT more bike then the 250s I've been riding.
- The left exhaust header seems to be discoloring faster than the right.
- Clutch lever feels stiff, takes a little muscle to use properly.
- I'll be at a stop, in neutral, I'll shift into first, the neutral light goes out, I start letting the clutch out to get in the friction zone to start off, and instead the neutral light comes back on & I'm somehow back in neutral. Right foot nowhere near the gear lever.
- there's a small rubber drain tube? that hangs below the engine, comes down from the canister under the fuel tank. I'm guessing it's emissions-related?
- all in all it's fun to ride, just haven't had the chance yet away from stop lights & heavy traffic. It's just much more than I'm used to, power & weight-wise.
Online Chuck in Indiana
Re: New to Guzzi -questions & observations...
« Reply #1 on: June 02, 2015, 11:21:19 AM »
Welcome to WG, Chuck.. good name, BTW.
Try pushing down on the gear lever while slowly letting out on the clutch lever. That lets the transmission turn enough for first to engage.
ajonen
« Reply #2 on: June 02, 2015, 11:45:48 AM »
drain tube is most likely to drain the overflow in the airbox.
Online Luap McKeever
  • Owner, WildGuzzi.com
  • Administrator
    • Wildgoose Chase Moto Guzzi
« Reply #3 on: June 02, 2015, 11:55:27 AM »
Welcome Chuck.
-You've got alot more cc's now too :-)
-Don't worry about pipes yet. It'll even out more than likely.
-Welcome to dry clutch world.  That'll get better with time too.
-Your Guzzi wont even be broke in until at least 5,000 miles.  Stomp that sucker into gear until it gets smooth.
-Ride that sucker.  It'll only get better with time.  Just like a fine wine :-)
2021 V85TT Centenario E5
2001 California Special
2001 California EV
2007 Honda Goldwing GL1800
« Reply #4 on: June 02, 2015, 12:37:17 PM »
On the clutch, if it doesn't start improving sometimes it needs better adjustment... I think the spec allows a tiny bit too much freeplay (at least it has on a couple of examples I've ridden).
But mostly, just enjoy!
Offline kevdog3019
« Reply #5 on: June 02, 2015, 12:49:32 PM »
Since you only mentioned stiff clutch and not being in first, I'm not suspecting clutch adjustment is out.  As Chuck mentioned push down on the shift lever (left foot... I think you had a typo) and slowly let out clutch (at stops) and it will engage.  Compared to your 250's the clutch may feel stiffer.  Enjoy the ride!
Welcome most of all.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
« Reply #6 on: June 02, 2015, 12:58:19 PM »
True, but it's seemed common enough and not everyone describes their trouble as well as we would like sometimes...  :afro:
Offline sib
« Reply #7 on: June 02, 2015, 01:09:56 PM »
Yes, it happened to me a few times.  The 6-sp gearbox is different from the 5-sp in this regard.  I've gotten into the habit of making sure it's in gear by letting the clutch lever up a bit and feeling the pull.  If you have your foot on the shift lever while doing this, it gets in gear and stays there every time.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline sib
« Reply #8 on: June 02, 2015, 01:13:46 PM »
There should be two similar-looking hoses ending there, one coming from the carbon canister (which, as you pointed out, is now located under the fuel tank, moved from it's previous location dangling from under the bike) and the other one coming from the tank filler drain moat.  That hose begins at a fitting near the rear of the fuel tank bottom.
Offline segesta
« Reply #9 on: June 02, 2015, 02:57:47 PM »
Chuck D? Man, I _loved_ "Ice Ice Baby"!
(that's a joke, guys)
2013 Ducati Monster 796
2010 BMW K1300GT
Offline Chuck-D
« Reply #10 on: June 02, 2015, 04:44:53 PM »
Yes, I meant "left foot" !!
Clutch feels stiff always, but it's only a problem in first.
I'll practice being on the shift lever when I'm letting the clutch out from a stop.
Thanks for all the advice, everyone !
