Author Topic: ecu ground  (Read 2456 times)
Offline rdbandkab
ecu ground
« on: June 03, 2015, 05:44:14 PM »
Hi all,
Dumb question (but with good pic!).
Is the connection circled in red the ecu ground?   I'm trying to go over the bike for any loose connections, fairing bolts,  shifter linkage bolts,  and grounds.   I checked the circled bolt,  but wanted to make sure the ecu ground wasn't hanging off the back side of the ecu..  Then it would be a tank off proposition..  Or a tankless job.. :laugh:  sorry.
richy
« Last Edit: June 03, 2015, 05:45:24 PM by rdbandkab »
Re: ecu ground
« Reply #1 on: June 03, 2015, 06:32:17 PM »
Yup, that's the earth strap. They can be a bit flakey so there is no harm in running another one to somewhere solid on the engine.
Offline rdbandkab
Re: ecu ground
« Reply #2 on: June 03, 2015, 06:43:18 PM »
Thanks Pete!
