Author Topic: Want to confirm terminology in service manual regarding fluid change.  (Read 3368 times)
Offline Toecutter
I have the service manual, I ride a shiny new 2014 V7 Special.
In it, it states that the transmission takes 85W-140, and the gearbox takes 85W-90.
Are they referring to the final drive when they say "Transmission"?
Also... I haven't removed the valve covers yet, but will be tomorrow evening to adjust them as per 1000 km service specs. Will I be removing the rocker arms to torque the heads? What size hex drivers do I need for the job? I'd hate to get in there and realize I need to make a run to the hardware store.
edit: Also, I can find a torque value for the oil filter cover, and oil drain plugs, but nothing for the filler plugs?
Thank you!
« Last Edit: June 10, 2015, 11:39:58 AM by Toecutter »
 Yes , transmission = final drive . MG really needs to straighten that out , it has caused problems . Don't know if the SBs have a hidden stud like BBs that requires the rocker arms to be removed .
Offline Toecutter
Thank you.
'transmission' is the Bevelbox on the rear of the swingarm. 'gearbox' is the thing behind the engine.
No need to remove the rocker arms to re-torque the heads on a smallblock. What you'll need is a 17mm socket, a 10mm alien key socket, either a long one or a 3/8ths drive one and an extension and a 12mm deep socket, also preferably 3/8ths drive.
The rocker support studs have 17mm nuts, the outer two sleeve nuts are 10mm allens and the top/inner stud has a 12mm nut. 17 &10mm allens are 30-32 ft/lbs. 12mm nut is 20-22 ft/lbs.
Filler plugs are torqued to common sense.
Offline Toecutter
Perfect.
Thank you very much.
Offline davedel44
Gotta love Pete.  :thumb:
Dave
Galveston
Bambino- 2013 V7 Stone
Offline sib
...Filler plugs are torqued to common sense.
Or for those of us with less common sense than Pete, about 12 Nm is good.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
