Author Topic: Tank Badge removal  (Read 4370 times)
Offline Bobbilljim
  • Eternal Student
Tank Badge removal
« on: June 12, 2015, 01:36:32 PM »
 how do you remove the plastic Moto Guzzi badge on the side of the Cal II tank? Without breaking it?
Rob
"There's Guzzi Cheap, then there's Stupid cheap" - Fotoguzzi
1984 California II
Re: Tank Badge removal
« Reply #1 on: June 12, 2015, 02:15:53 PM »
If I recall correctly there is a pair of spikes on the back that fit into holes in the tank.
I believe I used a drywall spatula (narrow one), slide it under and twist.
Mine came off without breaking but if the worst happens you can fix them back with double sided tape.
Offline Spuddy
« Reply #2 on: June 12, 2015, 02:53:09 PM »
Double or triple up some dental floss.  Works a lot more often than not...
Spud
'13 Stelvio NTX
'07 California Vintage
'01 W650
« Reply #3 on: June 12, 2015, 03:29:07 PM »
  Air chisel.
Online rodekyll
« Reply #4 on: June 12, 2015, 03:53:15 PM »
Have someone else do it.  Then it's not you breaking it.    :boozing:
The spatula idea works for not breaking it, but it will warp it.  Then it looks like the HoLlYwo0D sign.
Have not tried dental floss, but it could work.
Offline LeRoy
« Reply #5 on: June 12, 2015, 09:34:47 PM »
I believe that you'll find the tank badges to be die cast metal parts, not plastic. It's fairly flexible when removed and pretty easy to bend or distort if you're not careful. That being said, it's also reasonably easy to gently bend it back into shape unless you bend it too sharply when removing (see below).
As noted, there are two posts on the back of the badge that press into matching holes in the tank. There are also little metal clips in these holes that help the posts snap into place and hold retention.
I've found that the best way to remove the badges is to pry them off with a thin plastic tool. The kind of tools that you can find in auto parts stores for removing interior trim or radio face plates are good for this purpose. Like these:
http://www.ebay.com/itm/Car-Door-Plastic-Trim-Panel-Dash-Stereo-Audio-Radio-Installer-Removal-Pry-Tools-/201258227428?hash=item2edbecd6e4&item=201258227428&vxp=mtr
Don't start prying the badge off at the very end; start about an inch in from the end. That's approximately where the mounting posts are. If you start lifting the at the end, you may put a sharp bend in the badge right where the post is. Experience talking. Lift it a bit at a time and place a shim of some sort under the badge as you pry one end up a little bit, then the other. It should come off without much struggle (unless some previous owner has used the double stick tape method to put it on).
When you put the badges back on, you'll want to make sure they are not perfectly flat. You want to have a slight curve in the badge to match the curvature of the tank where they mount. Make sure the little metal clips are in place in the tank holes, then press the badges back on.
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
Offline Bobbilljim
  • Eternal Student
« Reply #6 on: June 13, 2015, 10:30:31 PM »
thank you all! Success!!! I used a putty knife to work around the edges until I could get a plastic scraper under the badge near the studs. After that it was just a matter of patience and wiggling. Didn't tweak them a bit!
Rob
1984 California II
Offline jbell
  • Some progress
« Reply #7 on: June 15, 2015, 04:49:09 PM »
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
