Author Topic: Cylinder Head Retorquing  (Read 2968 times)
Offline cloudbase
« on: June 15, 2015, 04:24:07 PM »
It's something of an article of faith in our community that heads have to be retorqued following a head gasket replacement.  Is this one of those anecdotal things, or is it based on something concrete?
I've never done a motorcycle before, but have done a few cars and a whole lot of marine diesels, from auxiliary to the 900 mm bore propulsion ones.  Never had to retorque after replacement,
and never had a problem.
Your sage input is most welcome.
Re: Cylinder Head Retorquing
« Reply #1 on: June 15, 2015, 04:33:11 PM »
It's needed on older Big blocks that use Kingerlite head gaskets and all the Smallblocks but later big blocks and the 8V's use composite steel gaskets that don't require re-torquing.
« Reply #2 on: June 15, 2015, 04:55:33 PM »
Depends on model. G11 and B11 from about 2007/8 I think. The Calis didn't get them until slightly later I think. At the end of the day though the year doesn't matter as the big blocks were always over-torqued ex-factory and rarely cause problems until they're rebuilt. It's when the heads have been off that it's vital to follow the re-torquing schedule and since you will of had the heads off you'll know what gaskets it has. If Kingerlite? Re torque. If composite? Don't.
Offline cloudbase
« Reply #3 on: June 15, 2015, 04:59:40 PM »
Thanks.  It's Klingerite, but has metal reinforcement around the cylinder bore.  This for a 2000 Quota.
