Author Topic: Rear cover for 5 speed tranny  (Read 3036 times)
Offline Goosecoop
« on: June 20, 2015, 09:40:42 AM »
Does anyone have a rear cover for a 5 speed they would be willing to sell? The tranny I am working on has a bearing seat that has been chewed up by a ham fisted previous "fixer."
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
Offline Rolf Halvorsen
Re: Rear cover for 5 speed tranny
« Reply #1 on: June 21, 2015, 10:39:07 AM »
Yes I have several different rear covers. The differences are small - but which model do you have?
Rolf
Offline Goosecoop
« Reply #2 on: June 21, 2015, 12:33:06 PM »
Hi Rof,
This tranny is out of a T3. It's a 5 speed. Would a part number from inside the cover help?
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
Offline Goosecoop
« Reply #3 on: June 21, 2015, 01:53:23 PM »
Well, got deeper into the tranny and found 3 gears are rusted and pitted to the point where they would need replacing. That's going to result in about $700 in new gears. Then there is the bearings that need replacing. Anyone have some good used gears also?
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
« Reply #4 on: June 21, 2015, 02:42:42 PM »
 Yes let me have the number engraved on the inside.
According to the part number catalog for a T3, the specific part number of the lid should be 18200802.
I think the engraving will show 18200801
You need to specify which inside parts you need.
I rebuild gerboxes as a hobby - but due to I live in Norway with a high shipping cost for gearboxes to USA, it will probably not be a good idea to purchase a rebuilt one from me.
Rolf
Offline Goosecoop
« Reply #5 on: June 21, 2015, 07:03:26 PM »
Hey Rolf,
The number inside the gearbox cover is 14200810.
Mike
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
Offline Goosecoop
« Reply #6 on: June 21, 2015, 07:10:24 PM »
The inside parts for the transmission I need are:
3 gears:
one with 22 teeth - I believe is 3rd gear
one with 25 teeth - I believe is 2nd gear
one with 28 teeth - I believe is 5th gear
These are all on the layshaft or if I have my terminology wrong it's the one that sticks out the rear of the cover and attaches to the u-joint.
I also need the bushing or collar that sits on top of the output shaft and holds a small ball bearing. This bushing has threads on it external side and is under the oil seal. I've forgotten what it's called and am too lazy at present to go look at the parts diagram. So sorry.. let me know if you need the part number and I will look it up.
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
« Reply #7 on: June 22, 2015, 03:57:56 AM »
Hi again
Yes I have this end cover. Send me a personal message with your mail address so that I can send you picture and description.
one with 22 teeth - I believe is 3rd gear (14214810)
one with 25 teeth - I believe is 2nd gear (14214510)
one with 28 teeth - I believe is 5th gear (14214210 This is the 1rst gear)
I also need the bushing or collar that sits on top of the output shaft and holds a small ball bearing. (14762510 and is only sold as a set with the outgoing speedometer axle)
The best for these small parts are to buy them new. Then we do not need to discuss the quality of used ones.
Rolf
Offline Goosecoop
« Reply #8 on: June 22, 2015, 01:29:14 PM »
OK Rolf. PM sent.
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
