Fifth gear will be cactus. Oiling problem back in the day.One suggestion would be to buy a Breva 750 box off the Bay of Fleas as these have all the later mods that seem to have cured, or at least mitigated, the fifth gear extinction problems. Take a litre of oil without blowing it out everywhere too.Pete
To be honest Chuck I have no real in-depth knowledge of the differences in primary ratios and would have to look them up. If it were me though I'd just bung it in and see how it felt. I don't think it would be too different. One would assume that the B750 would have a slightly lower ratio? I do know of people who put V35 primaries in their V50's to lower the gearing to make them better for bend-swinging in the hills.If you do that what's the worse that can happen? It feels a bit frenetic on the freeway? Well, get off the freeway! Pete
Chuck, My experience with a Beaver trans and my cafe Lario are pretty equal. Yes, I have the V65 primary on the cafe. I LOVE it. I owned a B 750 so yes it's close. The Lario stock primary is very high and built for outright speed at the sacrifices of low end. I would bolt it up and enjoy the new primary unless you want to hit the ton plus a whole lot more. K
I'll give it a try. Better not hurt my 50 mpg too much, though.. (Guzzi content)
So bying a breva gearbox will give me a little less top-speed, a bit better acceleration.Didn't quite get the other bit, do I need to buy the gearbox-cover of the breva, or can I keep the lario gearbox-cover?
Sorry, can you expand? I don't understand what you mean. Are you saying you want to use one of the cases from the Lario box? If so why?Pete
I hate to say it, but that nut is damn near impossible to undue. Bring it to a shop and have them try it. Guzzi or BMW shop. You are talking the main output of transmission shaft??Not sure about the gears fitting but my guess says nada. If you want to go that route, don't worry about that nut and buy a beaver box and leave the Lario box as is.
Regular threads-- lefty loosey. It is peened that nut.
In my experience, using steel brushes to clean off the rust is not very effective because it is very difficult (impossible) to remove the rust and still retain the VERY thin chrome plating.As soon as the plating is gone, the rust returns immediately.Regarding the fork tubes, I would recommend new ones for sure. Even if you could get all the rust removed, you still would have a very irregular surface. This rough surface will grind away at the seals and ruin them also, with leaks to follow. In fact, the seals are probably already compromised. New tubes and seals.
