Author Topic: cant find bearing !!  (Read 5547 times)
guzzig5
« on: June 25, 2015, 03:05:00 PM »
5 speed gearbox , main /cluster shaft
Front of transmission (MG# 92256218):
17 mm ID × 35 mm OD × 15 mm wide - this is a needle bearing
Durkopp 10-2762
RIV NAS 17
Torrington 10-2762
Timken 10-2762
Where can I find one of these ? Also could I swap this out for a single roll ball ?
guzzig5
Re: cant find bearing !!
« Reply #1 on: June 25, 2015, 03:22:42 PM »
Looks like harper has one for 78 dollars . yikes !
« Reply #3 on: June 25, 2015, 04:39:37 PM »
Note that the bearing has an oil gallery around the outside and there are drillings to allow the ingress of oil through these to the needles. You can get a MUCH cheaper, dimensionally identical bearing that doesn't have the gallery and drillings. It won't last very long. Also do NOT use bearing mount when installing!
« Reply #4 on: June 25, 2015, 04:49:42 PM »
I'm too lazy to look, but have you tried Motion Industries?
« Reply #5 on: June 25, 2015, 05:38:04 PM »
I haven't tried Motion figuring that if Emerson Bearing can't get it for me, then neither will they. Might be something that Peters Bearings in Germany could supply, but would most likely cost the same with shipping.
Online RinkRat II
  • Lake Powell AZ
« Reply #7 on: June 25, 2015, 05:47:31 PM »
 Kaman if  Motion doesn't have it . :popcorn:
    Paul :boozing:
