So the 2 foot clear tubing is the overboard vent? Seems reasonable.
Joe, two things:1. That IS a vent hose I'm seeing at the top or is that inlet from the V covers? I do hope it's vented.The top hose is from the two valve cover vents and the clear line is the vent. 2. The drain hose to sump is running up hill. Should it maybe be turned around to flow out of the catch can? I'm not saying it won't drain, but you will have a good amount in there before it does.This is an experiment, it'll probably collect a little oil in the bottle but, it should drain back once it reaches the height of the hose, as long as it doesn't spew oil all over, I'll be happy!
If I'm understanding the OP, he's not messing with the actual breather. He's just disconnecting the hoses that feed fresh air from the air cleaner box and attaching them to filter pods instead. He wants to know if there's any reason (besides passively filtering the inbound air) for the hoses to connect to the airbox and not to some other filter source. If I'm reading it right the question could also be "can I pull the breather hoses from the airbox and let them dangle?"I don't have an answer. I'm just trying to be sure the right question is being discussed.
