Author Topic: 1974 Eldorado not sleeping in barn anymore.  (Read 5072 times)
Offline bassa99
« on: June 27, 2015, 01:33:27 PM »
Just brought home Eldo from long time buddy that has had bike in his family since new. Bike sat for about ten years without being ridden. He put it in service and rode it about 5000 miles since
1991.
It is on lift and I dropped oil pan and found what appears to be small rubber bits what could this be? Also the oil has very small specs of chrome with some collected against oil screen.
I know I will have to replace cylinders, should the lower end be torn down or can I some how rinse out this area?
Plan to remove heads next week to see how bad bores are.
TIA
Allan
1999 Bassa
2001 Confederate Hellcat
1973 Norton Commando restoration project
Offline twhitaker
Re: 1974 Eldorado not sleeping in barn anymore.
« Reply #1 on: June 27, 2015, 01:46:41 PM »
You will need to take it completely down. The rocker pins will need to be checked as well as the bottom end.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline Shorty
« Reply #2 on: June 27, 2015, 01:58:14 PM »
Rubber bits part of timing chain adjuster?
« Reply #3 on: June 27, 2015, 02:02:02 PM »
 :1: on the top end.  What part of the country?  Flecks of chrome indicate the liner is falling apart.
Offline Testarossa
    • Skiing History
« Reply #4 on: June 27, 2015, 02:26:49 PM »
Rubber bits come from the timing chain tensioner. Chrome flakes mean the cylinder liners are shot, and since the chips floated through the oil lines, all the crank bearings are probably scored and therefore must be replaced.  Enjoy the process!
Offline LeRoy
« Reply #5 on: June 27, 2015, 10:19:10 PM »
In addition to the advice above, you get a 1000 word discount on your next post it you include a picture.
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
Offline Yukonica
« Reply #6 on: June 28, 2015, 12:09:54 AM »
 :1:
« Reply #7 on: June 28, 2015, 10:10:31 AM »
Better tear it down or it will be "sleeping with the fishes".
Offline Mike Harper
    • harpermoto.com
« Reply #8 on: June 28, 2015, 10:49:53 AM »
OR
Some nitwit has used silicone seal somewhere on the engine.
Offline mtiberio
    • TiberioRacing
« Reply #9 on: June 28, 2015, 12:48:54 PM »
Rubber from chain tensioner
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline JoeW
    • The Guzzi Doctor
« Reply #10 on: June 28, 2015, 12:52:29 PM »
Joe Walano
Offline NCAmother
« Reply #11 on: June 28, 2015, 01:12:49 PM »
that's what I found to be in my 850.  Once they start to wear down, they go quick
Howdy
