Author Topic: v io centauro camshaft position sensor  (Read 2988 times)
eweltd
« on: June 28, 2015, 04:26:18 PM »
hi all
if my cam sensor is not working what way will the bike perform and how do i test it , sensor has 3pins.
eric
Re: v io centauro camshaft position sensor
« Reply #1 on: June 28, 2015, 05:13:50 PM »
If it ain't working it will either not run at all or, if your bike has the P8 controller it may run but will die the moment you open the throttle. I think that Centy's use the 16M though.
eweltd
« Reply #2 on: June 28, 2015, 06:18:11 PM »
sensor is an sen 813 bike starts runs tick over can rise to 3000 rpm and hold for a while and drop to 1500 or less back fire trough air in take and cut out or go back up to 3000 and down and back fire and stop plugs are black and sooty.
eweltd
« Reply #3 on: June 28, 2015, 06:20:23 PM »
yeah it has a 16 m
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #4 on: June 28, 2015, 06:31:04 PM »
from 3 pins, one is shield, two others should have some 550-650 ohms. But it is not strange that the sensor fails. When replacing measure the depth to the tootth wheel inside. Should be the same as before . Airgap should be between 0.7 and 0.9 mm, In the centauro book they have 0.6 to 1.2mm
Paul
Daytona 1225, Stelvio 1151
« Reply #5 on: June 28, 2015, 06:37:17 PM »
« Last Edit: June 28, 2015, 07:13:10 PM by Charles in Lake Charles »
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
eweltd
« Reply #6 on: June 28, 2015, 07:17:37 PM »
thanks for replys
its 1 15 am in ireland keep replys coming wil catch up in morning.
eric
