Author Topic: Centauro Stand Bracket + Pics  (Read 6220 times)
Offline flangeman_70
« on: July 05, 2015, 08:34:16 AM »
Yesterday I was moving my bike and as I turned to walk away I heard a noise only to see my Centy in the process of laying itself down  :shocked: Luckily I managed to stop it from doing itself any harm. The bracket for the stand tore itself in two. I'll post photos later today, I was too disgusted to bother when it happened.
Anyway, does anyone have one of these laying around or know of anyone wrecking a spine frame bike.
It is the bracket that bolts to the timing chest and holds the side/kick stand.
Thanks.
Adam
« Last Edit: August 03, 2015, 03:18:05 PM by Flangeman »
Adam
SP III 1990
V10 Centauro 1996
Offline CT Dharma
Re: Spine Frame Stand Bracket
« Reply #1 on: July 06, 2015, 08:26:33 AM »
Thanks for the heads up; think I'll check mine out tonight. Would be great if you could post pics of the failure.
1980 SP1000 original owner
1998 V10 Centauro
1982 Honda CX500TC Turbo
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
"When I'm riding my motorcycle, I'm glad to be alive. When I stop riding my motorcycle, I'm glad to be alive" - Neil Peart 1952-2020
Offline twhitaker
« Reply #2 on: July 06, 2015, 08:31:59 AM »
Having a hard time believing that forging broke in half. Was the smaller (M5) screw left out? That screw came loose on my LeMans and I caught it as the bigger screw was wearing out its tapped hole.
« Last Edit: July 06, 2015, 08:55:27 AM by twhitaker »
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #3 on: July 06, 2015, 08:58:23 AM »
I heard of them breaking before. Mine lives now 13 years, solely on the big bolt. Because the V pan I have that doesn't have a mounting point for it.
Paul
Daytona 1225, Stelvio 1151
Offline CT Dharma
« Reply #4 on: July 07, 2015, 12:54:43 PM »
Mine looks good; any pictures yet of the failed piece?
1998 V10 Centauro
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
Re: Spine Frame Stand Bracket + Pics
« Reply #5 on: July 07, 2015, 02:28:38 PM »
Hi All,
After some research I learnt this was a known issue with the V10 models due to the casting and then machining process. The V11 unit wasn't prone to these failures and was offered as a free replacement at some stage due to the possible injuries. I was lucky as I had turned to walk away and heard it and it propped up as the stand slipped off the concrete pad and on to the grass. I was able to lower softly to the ground.
I have managed to source a center stand and several used brackets.
« Last Edit: July 07, 2015, 02:30:31 PM by Flangeman »
Adam
SP III 1990
V10 Centauro 1996
Offline twhitaker
Re: Broken Centy Stand Bracket + Pics
« Reply #6 on: July 07, 2015, 03:38:30 PM »
FWIW, I put a block, about 1 1/4" thick, under my sidestand figuring more vertical would put less stress on it.
MGNOC-11168
Dayton, OH
Offline CT Dharma
« Reply #7 on: July 08, 2015, 04:15:39 AM »
Adam
Thanks for the pictures. Can you tell me more about fitting a center stand on the V10?
1998 V10 Centauro
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
« Reply #8 on: July 08, 2015, 10:15:59 AM »
Hi CT,
I'll post pics when I carry out the installation which, if all goes to plan, will be this weekend.
I believe it is a TLM unit from the Netherlands.
Here is a link to one installed in the UK. http://www.centauro-owners.com/gallery.html
About two thirds down the page a yellow beast.
Regards,
Adam
Adam
SP III 1990
V10 Centauro 1996
Offline CT Dharma
« Reply #9 on: July 17, 2015, 07:36:27 AM »
Adam
Any update on the center stand installation? Seems like they're very rare to find; where did you get yours?
1998 V10 Centauro
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
Offline Joliet Jim
  • Justus Esto, Et Non Metue
« Reply #10 on: July 18, 2015, 08:09:35 AM »
thanks for this, i may try a small block under mine because the 2x6 sits it a little too upright. Also plan on inspecting it since i really don't need it going over in the garage. I managed to catch my trident when the side stand broke off of that old brit bike. Someday i'll get that welded back on.
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Just memories
The Psycho Chicken
The Fire Demon
Thumper
« Reply #11 on: August 03, 2015, 03:13:05 PM »
Adam
I got it from the owner of the very famous caf�'d Centauro http://thebikeshed.cc/2013/02/04/arnies-guzzi/
It fits perfectly and I am very satisfied. These are the only pics I had so far.
« Last Edit: August 03, 2015, 03:16:32 PM by Flangeman »
Adam
SP III 1990
V10 Centauro 1996
